Just wanted to bump this question to see if anyone knows.Reading earlier about some extended shackles binding on the Icon leafs - are the Camburgs the only ones that seem to be O.K.? I’d really prefer a 2” shackle.
Thanks
I haven’t actually installed mine yet, but I did buy a factory length camburg shackle to start. One person I remember reading about that had a binding issue wasn’t paying attention and had installed his shackles backwards. Another had over tightened everything. But maybe someone else can chime in...Just wanted to bump this question to see if anyone knows.
Thanks
Definitely do not over tighten the bolts. I did first go around to the gen 1 specs, then loosened things and retorqued a few days later and then rear springs sat down a little lower where they should be.I haven’t actually installed mine yet, but I did buy a factory length camburg shackle to start. One person I remember reading about that had a binding issue wasn’t paying attention and had installed his shackles backwards. Another had over tightened everything. But maybe someone else can chime in...
Are you suggesting that get the icon bump stop extender is a better option?
Have a photo from the side? Before and after measurements? Have the Eibach springs sitting in the garage and Icon’s on the way, still contemplating setting 1 or 2...Got my Icon Leafs (option 2), Geiser springs, and Forged Offroad bumpstop pads mounted! It was a decent project as far as the install going mostly as expected. We did struggle a bit with changing coils out on the shocks. So far, so good. I’m pleased. Everything seems a bit firmer... but in a good way!
If you could update me with your measurements after a week or two of driving to see how things break in.
