If I remember right the Icon truck runs stock springs, do they recommend sticking with stock with these shocks and bumps or will they work just as well or better with aftermarket springs and if so do they have a preference?
Ok, why the 2.0 bump vs the 2.5? You have done the heavy lifting when you posted so much detail, so 2.0 vs2.5 pros/cons?
An air bump is hybrid of a shock and an air spring. They can have some very odd characteristics however due to the fact that they are emulsion (gas and oil not separated), they are not connected to the axle, and the current impact partially depends on the previous impact(non linear).
As an air spring its characteristics are based on: shaft dia, stroke, initial pressure and compression ratio. The graph ramps up drastically at the end and how drastically is based on the compression ratio. We set it up for very high compression ratios and sometimes close to infinite or hydraulically locked. Here's the catch.....the shape of the graph is ALWAYS the same if set up this way regardless of size. See attached
The problem with an air spring of this nature is it doesn't really do much till the end of its travel so there isn't really that much energy to be stored. What we do is force it to develop some extra force earlier in its stroke with the valving on the piston. It is also velocity sensitive so the faster it hits the more it ramps the pressure up. This combined with a reasonable initial charge makes it so that first contact is mild and if it's a small hit doesn't upset the attitude or stability of the vehicle or its occupants but when hit hard will create(and dissipate) more energy earlier in the stroke and lift the chassis over the obstacle.
Does size mater? Yes at some point, but not because of heat or performance. It's relative to shaft size more than body size. At some point the pressures get hard to deal with and a larger shaft diameter is called for.
This dyno graph shows some of the characteristics of an air bump.
The blue line is very slow so the hydraulic part is not influencing it very much and the shape is very close to just an air spring
The red line is at 10 inches per second and shows the hydraulic effect add additional force. You can also see that there is a flat spot at the lower left corner. This is because due to the rate of impact as its cycled on the dyno the shaft has not had time to fully extend before the next impact.
The green line is at 30 inches per second and shows how it can develop forces much higher than just those due to nitrogen pressure and shaft diameter. This is being cycled much faster than the random bumps you would encounter in the field yet still returns to 60% of its travel.
The energy that is being absorbed is based on the area under the curve. So you can see that at low speed there is less energy to use the majority travel available and at high speed more energy is absorbed.
Note it is also important to tune the rebound correctly to not kick back but also not overdo it so that it extends to slowly. This is especially bad as it will pack up the bump on the first hit and the second one will slam extremely hard because there is no travel left. This pack up situation can be dangerous and is common when a large air bump is run at low pressure to reduce the initial contact force.
It is not uncommon to see wheel speeds over 100 in/sec
Yes
Energy = Force X Distance
If we simply dropped a truck from 10 ft we could take the potential energy of the mass of the truck at that height and equate it to (force X the travel of the suspension) for it to land and dissipate the energy.
But because we are in a more dynamic and varying situation that force would be way to high and would disrupt the chassis over every obstacle so we have velocity and position sensitive shocks and bump stops. A longer, bigger, high pressure bump stop will handle massive hits better but is more likely to upset the attitude and handling of the vehicle the rest of the time.
Here is a great example:
From 1:00 to 2:30
Ford Raptor Icon Testing - San Felipe, Mexico - YouTube
The best riding truck in this video is Theresa's truck. Why? It has an aftermarket spring that removed the block which has the arm on the side that engages the factory bump and there is no bump kit. So essentially there is NO bump stop, just shock and spring. This truck has more uninhibited up travel then the rest so within a certain range it is great. The problem is that prior to this trip she broke the upper shock mount from bottoming the shock in Glamis where there are big huge jumps and hard landings. For this trip we adjusted the long compression tube on the shock to dissipate more energy so she wouldn't bottom the shock as easily but it still needs a bump and would bottom on big hits.
So is a bump stop kit only needed for those OH Sh*t moments or does it aid the shocks in everyday use as well, and how about if you load your truck up with stuff or tow a trailer does it aid in anyway in those situations?
Nice write up, as always... looks good. Now go beat on it, so we can see what sort of abuse it takes!
Bird will take one lap at havoc before anyone gets there and will then proceed to park his purdy white truck for the remainder of the weekend. Pfff... Testing?
