ICON Bumpstop Kit Install Write-up
BIRDMAN
Birdministrator
Boston
ICON Ford Raptor Rear Hydraulic Air Bumpstop System
Available for sale through multiple FRF vendors: SDHQ, Raptor Addict, Outlaw Raptor, TMX, Freedom Motorsports, Krazy House Customs, and others.
Difficulty:
1 2 3 4 5 6 7 8 9 10
Time:
2-6 hours
I received and installed the ICON Hydraulic Bumpstop system late last week. I decided around the time of TRR '13 that I wanted a bumpstop kit after experiencing really for the first time how quickly things can go badly, especially when SPRSNK Rick marks the course. :goofy_batman:
I had the chance to ride along with Dylan from ICON during his initial testing of this kit, and I also spent time in the RPG truck, further experiencing the benefits of a bumpstop kit from the rear end control and added peace of mind.
This ICON kit is extremely impressive from the standpoint of initial overall quality and the obvious time that went in to the smallest details. The powder coat finish on the frame brackets, the welds, and the fitment really blew me away, and I mean that. The billet aluminum polished/clear anodized cross beam is a really nice piece too and as a whole this kit appears that it will withstand many New England winters from a corrosion standpoint.
I don't have a ton to add as far as the method of installation. I jabbed at ICON's instructions during my front 3.0 Coilover/ UCA install but in this case I can give credit where credit is due. The instructions ICON includes with this kit are extremely detailed and I am relieved that I don't have to do my own installation instructions :).
If you're considering this kit, the instructions can be found here for you to browse: http://www.iconvehicledynamics.com/wp-content/uploads/2013/06/95120_instructions.pdf
Here are my thoughts and impressions of the install its self.
1. I DID NOT remove the bed, as others have suggested. Honestly I can't see why anyone would remove the bed for this install. There are 2 bolts that are a bit difficult to get at, but with a selection of socket extensions, a pivoting socket head and a little patience it's not a big deal. Also, ICON provides a flange head nut for those two bolts which makes holding them in place with a socket much easier. Again, little details make this kit.
I started by jacking up the rear of truck until the tires were off the ground, removed the rear wheels, and secured the truck with jack stands and wheel chocks.
During the entire install, I just sat under the truck "Indian style" and was able to work comfortably.
This was basically my view. I should also note that since I have the MBRP turn down exhaust, I didn't have to contend with removing the exhaust. The MBRP turn down does not interfere at all with this kit, it's like a foot away from being in the way.
2. I have to admit that when I opened the box, I was little overwhelmed by all of the different sizes of nuts, bolts and washers to keep track of. Luckily, ICON clearly marks the parts bags #1, #2 and #3. Each hardware bag defines 3 phases of the installation according to the instructions. The installation actually goes very quickly once the main brackets are installed. And in reality, most of the bolts are either 1/2" x 1.25 or 1/2" x 1.50 so just make sure you know which is which and you'll move right along.
3. It's important not to tighten any of the bolts down on the main frame brackets until all of the bolts are in place. There is a tightening procedure outlined in the supplied instructions and I can reaffirm that you should follow that process. The brackets fit so snugly to the frame rails that you won't have much room to line up other holes if you have already tightened any of the bolts down. If you find that you need to maneuver the brackets to line up, you can use the handle of channel locks or something similar to stick through the bolt holes where the inner and outer frame brackets meet to pry slightly and line the holes up.
4. As I mentioned earlier, the fit and finish of this kit is exceptional. When you install the drivers side inner bracket, you need to pop the wiring harness and brake line retainers out of small holes in the frame. I was especially impressed with how the small 1/4" holes on the ICON kit lined up perfectly, allowing perfect alignment and re-installation of the factory retainers. With various factory variances and lots of room for error, it's clear that this kit is built with precision to fit so well.
5. When installing the cross beam and throughout this installation I referenced the diagram above to make note of which way the bolt heads are facing. I'm not sure if it's of any significance, but I found myself using the diagram more than the written instructions once I had a grasp on how the installation came together.
6. When assembling the tension rods, you will need to make note of the small notches on one side of the bar and 2 of the jam nuts. These identify the heim end side of the rod as being left hand threads. Your assembled rod should look like this (I used a little anti-seize on the threads):
I was a bit skeptical as to what these tension rods actually do, but it was apparent during the tensioning process that the bottom of the frame support clearly pulls in when you tighten the rods. Pretty cool how it really doesn't take much at all. A half turn either way on the tension bar and you can watch the frame twist in and out.
7. This is mentioned in the instructions, but it's important not to over-tighten the bolts which secure the bumpstops in to their sleeves or else it could effect how the bumpstop retracts. A tip for installing the bumps is to take a large flat head screw driver to spread the collar a bit and lube up the bump a little so it will slide in easier. Then just snug them down until you can't move the bumpstop by hand. I didn't pinch the collar together, I left a little space.
8. Here is ICON's solution for the striker plate. It's simple to install and effective. I believe it also works with aftermarket springs but I have the factory rear leafs. The strike pad hooks under the axle pad (where the factory block sits) and then bolts to the axle securely with a U bolt.
Overall, the installation took me about 4 hours. I'd say that's about average with hand tools. If you're a little less nimble, it might take longer and if you have air tools you could probably pull this off in 2-3 hours. The kit isn't difficult to install or understand, there's just a lot of bolts that need tightening!
I haven't had the chance to really test this kit out yet, but I plan on giving it a workout at Havoc in the Hills :headbang:
I engaged in some fire road shenanigans, speed bumps, berm and couldn't get the pad to make contact while on the road. I remember there was some talk of whether or not the bumpstops would hit on the street and from what I can tell they won't. Even if they do it would take a pretty gnarly hit and still I can't see that it would be possible on the road or of any consequence.
Beauty shots:
Fred
Richmond, VA
Good write-up...I would almost, and I say almost tackle this myself.
So, what is the main benefit you have seen with the bump stop kt? You metioned that things can "go badly", what exactly do you mean? Just curious.
Also, what is the point of the Tension rods? Why would anyone ever mess with them?
BIRDMAN
BIRDMAN
Birdministrator
Boston
The installation is really easy Fred. All you need is a complete socket set and a Saturday morning. It isn't difficult, just a lot of bolts to thread and tighten down which takes time.
By things going badly, I mean the OH SH*T moments. If you want to go fast, you're inevitably going to roll up on something that will kick your rear end. I saw it and felt it myself at TRR and got bitten by the speed bug too. I wanted rear frame support and control to match the capability of the rest of my truck. The 3.0's allow you to go a lot faster over the 1-2 foot stuff but when you hit the 3' stuff it's nice to cover your rear, pun intended.
The tension rods aren't something you would ever mess with, they are set it and forget it. They get a 1/2 turn of tension once everything else is tightened during installation and that's it. According to ICON they provide "inward" tension force on the bottom of the frame to counteract the twisting that may occur during a 1-sided hit on a bumpstop.
Fred
Richmond, VA
Thanks Bird...Makes complete sense. I am a fan of better to have it as well. Do you think it would be worth upgrading the leafs as well?
Plus the kit looks cool...
BIRDMAN
BIRDMAN
Birdministrator
Boston
Leafs are next for me I would say so
Raptor911
Ashburn, VA
Did you happen to weigh everything? I am **** about weight. The RPG bump kit weighs in around 100 pounds.
BIRDMAN
BIRDMAN
Birdministrator
Boston
I didn't, according to their site it's 70 lbs but I would venture to say it's all of that and then some. The FedEx guy looked like he was wrestling a greased up hippo when he took it off the truck.
Edit: Confirmed it weighs 70lbs
