Thanks, FP Forged! That is a good idea to try to get better quality travel out of what is available. That Rouge truck does rip I didn't know a stock front travel truck could move like that.
MurderedOutSVT do you have a format you follow for a proper intro?
As far as what I want to do with it is 1st make the weak points stronger to lessen the likelihood of breaking that part off-road. 2nd I'd like to be able to do small jumps with it. I don't want to spend the money for full-front suspension kits with UCAs, LCAs, and spindles. But I do want to be able to move at higher speeds off-road.
I have an idea of what I want to do for the rear of the truck I'm thinking:
Deavers +3
Drop shackles
SVC bump stop kit
Gen 2 shocks
KHC upper shock mount
Another guy on here gotsboost is running an almost identical setup with Icon RXT leaf springs and is pulling 15" of travel on a budget.
https://www.fordraptorforum.com/threads/how-to-pull-15-inch-of-travel-on-a-budget.89405/
This is why I'm seeking help because I'm not sure what is the best course of action for the front. Ideally, I'm looking for the best bang for your buck for front suspension travel or quality of travel performance increase. I'm looking to spend no more than $4K on the front. I've heard aftermarket UCA's can increase front-end wheel travel but I haven't seen much about that on the forums.
For the front, I want to run the Evil Manufacturing limiting strap kit and a tie rod kit. Other than that I'm not sure.
