Houston.... we have a problem
GCATX
King Dingaling
Central Texas
Man, after all that, no way I'm putting a tune on my truck if I had to fork over for a new motor.
I'm glad you got it back on the road though.
dillard09
dillard09
College Station, TX and Socal
There is nothing to break in as far as the engine goes- other than rings, and wide open throttle as early as possible is the best way to do that.
Yes sir. And it's been done. Multiple times. And I'll do a few more. Just want to change the plugs cause I'm sure they are gapped to 30. Also it has a stock T-stat and will be swapping in a 170 as well. So I'll do an oil change while I'm there. Do those before datalogging.
dillard09
dillard09
Haha! But I've got so much into it to just leave it alone now. Risk it to get the biskit!!
And I trust @GooseTuned
Old-Raptor-guy
USA
WTF that is weird.
Was going to answer but @EricM gave a great answer.
That is flame cutting of the block.
Too much cylinder pressure led to a head gasket failure. Combustion gets past the head gaskets and melts/vaporizes the aluminum block metal on it's way out.
Pretty similar to a oxy acetylene cutting torch...
On diesel engines they cut through the piston, all the way to the connecting rod. Normally a bad fuel injector in those cases.
