Hock's 2012 Raptor Build
Big Brother
So, Tizz's old rear ADD bumper installed ya, looks awesome!!! Painted everything that could rust underneath, painted calipers, installed my front flag bracket for silver lake...
Ha ha... Check out that ADD backwards in the camera!!
Here is my silver lake flag bracket
Got it leaning forward enough that it wont hit the truck...
Is it just me, or is that flag going to slam into the front of the truck when you go off road?
Wilson
South Dakota
I thought you had a receiver mount for the ***** in front. If so you could make something that go's in that.
IRONMAN
Well-Known Member
MICHIGAN
It's a pretty stiff flag pole and hence the angle on his mount also keeps it from hitting the truck.
Doesn't come close to hitting at all, trust me it's been proven. haha
H
Hockster
My 45ft Bluewater Party
Winchester, Va
Ok, I take the comment back about the harness being a easy move!! Only attempt this of you have a hoist!!!
Anyways harness moved winch wires ran and while I was moving the harness I had to remove the body mounts and what did find>>> the cups filled with water!!! What a shit design for sure. Reminds me of the 1986- 1991 taurus sub-frame platform. Ford was sued because the mounts would hold water and rust out then the engine and trans would fall dam near on the ground!!!
SO the cups on The rear body mounts of the Screw have a oil-hydro dampening cup on them that adsorbs the body boom here is a picture of the mount and the cup... I will drill a few holes so the water can drain but its not going to be easy the way its designed. I might take em off and see if I really notice the noise...
Heres what came out and remember this truck only has 4300 miles on it and might have 500 of them in the rain...
DirtNasty
Damn i was hoping that harness could be moved with out a lift because that is on the todo list. Interesting about the body mounts, mine must be sloshing with water given the water crossings i have done. :(
IRONMAN
Well-Known Member
MICHIGAN
These are what I think that are causing creeking noise when I turn from side to side. Happens every once in a while but in the summer time it happens more. Drives me up the wall.
