Update:
MY shit broke. 159k. Rear pinion.
This is what you threw in your Gen2 or Gen1? Same diff?![]()
High performance Yukon Ring & Pinion gear set for '11 & up Ford 9.75" in a 4.11 ratio | YG F9.75-411-11 | Yukon Gear & Axle
Yukon Gear & Axle high performance ring & pinions set the standard for quality. Yukon designed the gear tooth surface finish to reduce friction and heat, and use high grade steel in both the ring & pinion, with fitment designed to OEM specwww.yukongear.com
I haven't heh, just offering an option I would consider (Gen1). But pretty sure it's the same diff across generations aside from maybe shock/arm mounts for Gen3's, Yukon says 2011 and up for that ring & pinion...This is what you threw in your Gen2 or Gen1? Same diff?
Newbie here.. LOL.
Here I am not wanting to go over 20,000!Here i am not wanting to go over 100k
