I saw the other thread but it's not helping. Quick rundown:
The first row was already correct, but the second row I changed from 10xx to 01xx and this turned on the parking lights, however the low beams remain.
Any idea how to get the low beams disabled for DRL in a 2017? I don't want turn signals, just parking lights. Also, I've read about some max-brightness setting, is that applicable? Any help would be appreciated! (yes I have searched and I've been out to program it 5-6 times already with varying results and I'm a bit worried about the write error.)
- 2017 as it seems there are differences 2019-on.
- I originally tried to use the non-ASBUILT to select the DRL option but all this did was enable the low beams as DRL.
- After this, I was unable to change it as it gave the infamous write error.
- I consulted the spreadsheet and went to these settings in the ASBUILT section:
DRL - Parking Lights only (stock LEDs only) | BCM | 726-26-02 | x1xx | xxxx | xxxx |
726-50-01 | 01xx |
