Help me out with some ??? about my next mod. SVC tune or Lowrance external antenna
Labraptor
Illinois
I would go with the tune. Reason I say that is you have a concern (power and shifting) that bugs you all the time vs an intermittent concern (occasional loss of GPS signal). So, I would recommend addressing your more consistent issue first. From personal experience I think you will be happy with the improvement from SVC tune. Had the other then switched. Very happy after the change.
Also had the external antenna and the signal gain was tremendous. It is a very worthwhile investment. Plan on another when I put a Lowrance in again.
HAYNES OFFROAD
aka Wreckless
Bourbonnais, IL
You will definitely get the "butt dyno" power increase and driveability you are looking for with the SVC tune. Having just a k&n filter isn't going to do much in that department by itself.
I'm running a FRF grand opening sale, send me a pm or email, and I can get you setup with a quote, and a calibrated tune for your truck.
Bigg50
Benicia, CA
A good tune absolutely makes a noticeable difference in the butt dyno for these trucks. Well, it does if you have a CAI which you do. tbone drove my truck down to Noah's and was so impressed he immediately ordered a tune. I went with a single 91 performance/tow tune.
An antenna would be a lot cheaper than the tune/tuner and it's obviously important. Especially with the upcoming Black Ops run since you won't be able to see the dust clouds to help follow if your GPS cuts out.
Good luck with whatever you decide.
jackrook
jackrook
Bermuda Dunes, Ca
A good tune absolutely makes a noticeable difference in the butt dyno for these trucks. Well, if you have a CAI which you do. tbone drove my truck down to Noah's and was so impressed he immediately ordered a tune. I went with a single 91 performance/tow tune. An antenna would be a lot cheaper than the tune and it's obviously important. Especially with the upcoming Black Ops run since you won't be able to see the dust clouds to help follow if your GPS cuts out. Good luck with whatever you decide.
I'm leaning towards an antenna. Do you have the point 1 or the point 1 Baja?
slowest member of WCPR
Big Blue
Administrator
Staff member
Admin
USA
If you go the Antenna Route, you need the Point 1 Baja. The Antenna itself is the same with the Point 1 and the Point 1 Baja, but the Baja comes with additional parts and the power cord, which is why it's $250 versus $199.
If by chance you get just the Point 1, you can get the additional parts from Lowrance for $70.
All The Way
Lockport, NY
Plasti diped and no problems....
Big Blue
Administrator
Staff member
Admin
USA
Here is my set-up. I installed the antenna on the cross member of the RPG mount. I wanted it inside for protection and since the mount frame is sloped downward, it's barely noticable there. The Antenna does make a big difference.
RaptorFlipper
The Woodlands, Tx
Cannot comment on the antenna issue, but the tune will make a big difference addressing your needs for shifting, lag, etc. It is money well spent. I had the 5-star and loved it. So much I went SC. Get the tune!
