Yeah they sure do make it easy to wire up the LP6. Better then the old method of taking an LP4/LP6/LP9 dual harness and cutting the switch/components off (which was confusing to some not familiar with relays/electronics).
Available here: https://www.4x4truckleds.com/baja-designs-lp-series-controller-module-harness
Yes it's a newer harness that came out after the LP4/LP6/LP9. It plugs into the back of the LP4/LP6/LP9 and gives you bare wires to connect to things. A bit easier then hacking apart the normal harness. It's a 7' harness
http://www.4x4truckleds.com/baja-designs-lp-series-controller-module-harness/
Weird! I don't see on BD's site.
And I think I need 10 feet. I have to measure again. Thank you!
if you search for "Wire Harness" on your site, it does not show up in the results
Its under "wiring harnesses" but it would be nice if it came up under "wire harness" in the search bar. I'll get with my website guys today, thank you!
https://www.bajadesigns.com/products/Wiring-Harnesses.asp
