sixshooter_45
Mine is on the Home screen as well.
I think you have auto temp enabled. There are two settings. Last used and auto which uses outside temp to determine when and if seats and wheel are heated.Mine has a mind of its own. Just got off a great trip to the Carolinas this week. I don’t know how to turn it on or off but when it was cold out my wheel was hot and when it wasn’t cold out neither was the wheel. No idea.
This is how mine seems to work as well, although it doesn't exactly get burning hot or anything.
IIRC, there is a Forscan mod to put the heated steering wheel control on the main display (along with the heated/cooled seats), which I did and which makes it easier to turn on/off.
I thought I read that there was a Forscan hack to adjust the steering wheel temperature.
I'm still not sure if anyone's ever changed the settings and how well it worked, thoughI've never tried adjusting the settings, but I do see that there are temperature settings for the heated steering wheel in Forscan. Anyone ever tried changing those values?
Maybe that's where I read it. LOLYep, I already mentioned this earlier in this thead...
IIRC there is an adjustment for time duration of the steering wheel heater to time out and some have played with this. I don’t recall an ability to change temperature.I thought I read that there was a Forscan hack to adjust the steering wheel temperature.
I have new 2019 Raptor, I like the heated steering wheel, it only has one setting obviously, so once it warms up, I turn it off, by this time the heat has warmed the vehicle inside and I am good to go.
