H&M racing design long travel kit
Status
Not open for further replies.
C
canamds450
an LT kit isn't going to fix the small bumps, it will probably make them worse.
I agree with everyone else. Fly someone out to do the install. Talk to H&M.
I m not going to throw my truck to the desert, is mostly about looks and harsh terrain. In my country desert is flat and the roads are rought.
I m trying to get someone here to make a clean job, but i have not gotten any answer to be clear yet
Kevin at h&m is waiting to get a raptor at his facility, so he can send me a upper shock mount bucket welded within uppers a arms mounts.
I still trying to get a fair offer on the lts kit at the garage sale, but i need at least $12k for the whole kit to start on another lts option.
There are guys fishing, willing to pay $4,000 for metals parts and that is not going to happen
C
canamds450
Getting serious
Almost there
I m looking to mod the per shock, i can use upper a arms mount too.
Need just to weld a side mount out of the stocks ones
C
canamds450
Getting there, looking to mount the UCA
The stock front mount align with the new mount i will use stock front mount and get an outside mount at the rear
Call me crazy, but shit are already done. Looking how i still use stock mounts as plan a, is that doesnt work will have to save stock mount and remake the new ones
Raptizzle
FYT
Southern CA
Hope for your sake it somewhat works but I honestly think you're ******* up a perfectly good kit by re-engineering it. The good news is it's your money and only metal.
ntm
Alberta, Canada
Exactly, if you're going to **** around building one new uca mount, you might as well just do two and install the kit properly.
The clearances on these things are tight, 1mm in places when the suspension cycles. There is no way shifting the uca back like that is going to work for clearances or proper geometry.
You are creating twelve more problems while trying to solve one.
If you're committed, just start cutting and grinding, do it right, or don't do it at all.
C
canamds450
Yes, i know. I dont going to beat this kit down to the desert, as long it rides will be fine.
Will be using it like that for a while i get a good offer for the kit
I talked to kevin from h&m racing design and he will be sending me a upper shock mount bucket with UCA pivot mount welded in one piece
This is a upper shock mount from a build of outlaw offroad. It is very difficult to buy from those guys
---------- Post added at 03:30 AM ---------- Previous post was at 03:18 AM ----------
I got a digital angle
A digital caliper
And a square ruler
A lever and used my iphone to lever the truck too.
If plan A doesnt work, will take plan B.
Plan B
Save the stock mount with a disc grinder, and remake the new mounts with all those digital meassures
It says LCA ride height level need to be at 16 degree
Upper shock mount bucket need to be at 90degree
Mounts going to try it on a table first and check alignment then, if is good will take second shot at the frame.
TXRPTOR37
Are you high?
Status
