GEN3 Forscan
Jmeo
Massachusetts
You can just turn it off in your dash. I have a 2023,
Under - Features
Then - Driver Assistance
Then scroll down to the bottom, and turn it off
Correct, I have been using it this way for the past 5 months but every time I put the truck in reverse I get an alert pop up inside the gauge cluster saying that it has been turned off. I am wanting to get rid of the alert that pops up and I thought doing this in ForScan did just that.... Am I wrong?
Antho
@Jmeo have you driven it after making the change? I know sometimes if you make changes in the IPMA you will get that until you drive it and the truck relearns steering center.
Jmeo
Massachusetts
I did not try driving it. Every time I see the alert my scared ass reverts it back to stock, ha-ha. Could it be that simple?
Jmeo
Massachusetts
With the reverse braking assist turned off inside the truck settings as such:
I get this EVERY TIME I put the truck in reverse:
Hence the trying to turn it off in ForScan
Edit: Now that I think about it, I can not be sure it always did it (bad memory), but it has been for the past month or so. Only thing I can think of is that the OTA update changed something and now it's doing it?
Antho
@Jmeo could be. Make the change, once the change is made clear any DTCs and go do a little test drive.
Jmeo
Massachusetts
Shouldn’t you be looking behind you or at the backup cam if you’re backing up? :)
I hear you......but
Having been driving fire apparatus for over 20 years I only use side mirrors. As I turn to look mirror to mirror I cannot help but see the irritating alert on the screen and my OCD wants it gone. I am POSITIVE it was not always there.
Jmeo
Massachusetts
This seems wrong to me with my past experiences with ForScan. I do not think this is the answer.
**Says the man who has been married twice, and therefore wrong at least twice**
Antho
@Jmeo i just looked at it. Looks like a config incompatible DTC. I’ll look into it.
Members online
96,139
59,972
23UniFordicorn23
