GEN3 Forscan
Antho
Anyone know what DTC P160A is and how to permanently clear it? Keeps coming back after I clear and restart. Think it’s related to the speedo recalibration.
I’ve done:
75% DRLs
DRL includes parking lamps
Adjusted my speedo for the factory 37s
Disable Double Honk
@asteele711
Try the PCM and TCM relearn. Pretty common if you change the tire size and don’t do the relearn.
asteele711
Oklahoma
@asteele711
@asteele711
I figured that was the issue. Do you have a link for a thread where it shows how to perform a relearn? or could you share the the steps needed?
Thanks in advance!
EMc2
Phoenix
Has anyone successfully enabled Glare free on a '22 JOB 2 build? I've had no luck. Just want to confirm whether anyone has done it before I keep hammering.
Littlefx4
Don’t see why the parameters would be any different. Just back up your modules before you start hammering. If it doesn’t work, revert back to stock.
KCHawkeye02
Anyone know the codes to switch to baja exhaust mode on start up? My neighbor seems to like loud music at night...
lol. definitely interested if this is possible. I searched that forscan spreadsheet, no mention of "baja".
KCHawkeye02
What do the dashes mean at the end here? this is from the master spreadsheet.
Keyfob Tailgate Release - disable
BCM 726-61-01 xxxx xxxx 00--
Prevent headlamp switch from defaulting to Auto position
BCM 726-74-01 xx01 xxxx xx--
why are they not xx instead?
KCHawkeye02
Added a Few more items.
DRL INCLUDE FOGS
726-39-01 02xx xxxx xxxx
FOGS STAY ON WITH HIGH BEAMS
726-39-02 xxxx0 xxxx xxxx
DRL INCLUDES PARK LAMPS
726-38-01 xxxx xxxx 01xx
DOUBLE HONK DISABLE
726-63-02 xxx0 xxxx xxxx
LANE CHANGE BLINK NUMBER WITH DEFAULT 8C
724-01-01 xxxx **xx xxxx
80=NULL, 84=1, 88=2, 8C=3, 90=4, 94=5, 98=6, 9C=7, A0=8, A4=9, A8=10
LANE CHANGE BLINK NUMBER WITH DEFAULT 0C
00=NULL, 04=1, 08=2, 0C=3, 10=4, 14=5, 18=6, 1C=7, 20=8, 24=9, 28=10
OFF-ROAD IOD
7D0-01-03 xxxx xxxx 2xxxx
OFF-ROAD IOD #2
7D0-01-04 xxx6-xxxx-xxxx
**MY FACTORY WAS 4**
ADD OIL TEMP TO MEASUREMENTS PAGE
720-06-01 xxxF-xxxx-xx
SETTINGS MENU IN CLUSTER
720-10-01 xxx4-xxxx-xx
MY FACTORY SETTING WAY C. VERIFY YOURS BEFORE CHANGING
typo in one of your entries. Should be this for Fogs with high beams. Thanks for putting this list together!
726-39-02 xxx0 xxxx xxxx
