GEN3 Forscan
Antho
May have found a better option for the DRL brightness. If you did the mod that I deleted I would revert and use this. It just changes the duty cycle so you can actually set what brightness you want. I included the values below. I would discourage going to 100% as we had some folks with flicker (me included) with the old configuration. (The old configuration used 100% all the time and may be why the flickering occured) I’m currently at 75% and will keep an eye on it.
DRL_Ckt_FixedDim_DutyCycle_Cfg
726-38-01 xxxx **xx xx--
64 =100%
5A = 90%
4B =75%
32 = 50%
19 = 25%
0A =10%
Littlefx4
64 =100%
5A = 90%
4B =75%
32 = 50%
19 = 25%
0A =10%
As always, thanks for posting @Antho! I will screenshot this and hang on to it but I am one of the lucky few, I guess, that hasn’t had any flickering with your initial/old configuration.
Rick955
CT
64 =100%
5A = 90%
4B =75%
32 = 50%
19 = 25%
0A =10%
Tried 75% too... looks good so far!
WTX
The Permian Basin
I still for the life of me cannot get the auto start stop turned off on my 21. I’ve tried this code below, toggle switch, the steering interruption code. Still works as ford designed.
I added more settings in the instrument cluster (IPC) like the Gen2 had vs digging through the center stack (APIM) to make changes. The lack of access to some of the modules just made it a waiting game for some stuff.
720-10-01 ***X **** ****
Antho
@WTX
That code has nothing to do with auto stop/start.
DCM
Is it possible to use Forscan to have the exhaust mode default to quiet? 2022 without Quiet Start option in settings.
Antho
I notice it was removed. Not sure why. The Quiet time mode in the apim is
FoE Seatbelt Warning Strategy (FESWS) • Quiet Time Exhaust Mode (QTEM) • Clear Exit Assist (CEA)
7D0-09-05 xxxx-xXxx-xx--
0 =FESWS Disabled • QTEM Disabled • CEA Disabled8 =FESWS Enabled • QTEM Disabled • CEA Disabled
1 =FESWS Disabled • QTEM Disabled • CEA Enabled - Egress Warning9 =FESWS Enabled • QTEM Disabled • CEA Enabled - Egress Warning
2 =FESWS Disabled • QTEM Disabled • CEA Enabled - Egress PreventionA =FESWS Enabled • QTEM Disabled • CEA Enabled - Egress Prevention
3 =FESWS Disabled • QTEM Disabled • CEA Enabled - Menu Setting DisabledB =FESWS Enabled • QTEM Disabled • CEA Enabled - Menu Setting Disabled
4 =FESWS Disabled • QTEM Enabled • CEA DisabledC =FESWS Enabled • QTEM Enabled • CEA Disabled
5 =FESWS Disabled • QTEM Enabled • CEA Enabled - Egress WarningD =FESWS Enabled • QTEM Enabled • CEA Enabled - Egress Warning
6 =FESWS Disabled • QTEM Enabled • CEA Enabled - Egress PreventionE =FESWS Enabled • QTEM Enabled • CEA Enabled - Egress Prevention
7 =FESWS Disabled • QTEM Enabled • CEA Enabled - Menu Setting DisabledF =FESWS Enabled • QTEM Enabled • CEA Enabled - Menu Setting Disabled
DCM
Awesome! Thanks
