GEN3 Forscan
Antho
Just FYI, this setting turned off the entire driver side audio for me after rebooting. I was like, uh.... thats not good... seems like 21s and 22s are coded very differently. I think someone mentioned that the 22 raptors are programmed more along the lines of the f250/350/450 trucks. I am struggling to find how to turn the doo-dee-doo x 3 on key on... also, any way to disable the pop up banners "Step on brake to start" pop up? or disable start up animation on a 22???
I just did the Glare Free mod and its AWESOME. Seriously cool. Now just need to replace the factory fogs/driving lights for more output. The factory lights are a bit weak IMO
The apims, from what i have seen arent different in the asbuilt configuration. Maybe the reboot itself caused it? Regardless, your the frst person i've heard have this issue.
kpecks
Florida
Ya it’s pretty weird. I switched it back to Asbuilt factory and speakers were activated again. I do have a few other DTCs that popped up in forscan though.I have no CELs on the dash and no other warning banners that pop up.
The last DTC - PSCM BATTERY VOLTAGE is probably because I spent way too much time in the truck messing with forscan and let the battery run down lol. I was worried I messed something up because entry/exit lights and perimeter lights weren’t coming on but realized the battery was low.
ganooch
Dallas, TX
Lol, I just turned in my vehicle for service work and didn't revert the FORScan changes. Thought of that too late. Will be interesting to see if they find anything changed, especially when they are doing the recall for the trailer brake controller that requires a module update.
MDJAK
NY
I was curious if it would revert to stock after service but watching forscan changes done to specific modules, unless they can do a global reset and have reason to, I don’t see it happening.
gobluejd
HAIL!!!
NW Indiana
I have several FORSCAN changes, brought mine in a few weeks ago for (3) Recalls (Underbody Insulators, Powertrain Control Module and Trailer Relay) and nothing was changed for me.
ganooch
Dallas, TX
Great to hear. I am sure if I go in there complaining about the headlights and they see that I enabled glare-free, there will be an issue, but nothing I have changed is related to the moonroof, the A/C, or the trailer brake controller, so I hope I am good to go.
Littlefx4
Don’t worry; you’ll be fine! Just had this one done too. They’ll only reprogram the affected module…nothing else. See my paperwork.
