GEN3 Forscan
Andrewalker7
Hey all- 2024 here, and I attempted to turn off the seatbelt chime for the front seats, following the spreadsheet... but with no luck. All of my other changes worked immediately, but this one- any solution?
Forgive me if it's been discussed, I attempted a search but found no direct answer/resolve. Thanks!
hamster
Northern VA
4 changes are needed to remove the seat belt sound and visual. It will leave a DTC in IPC, but apparently that does not cause a problem.
swoop1156
USA
Here's a crazy one for everybody..
Is there a way to enable my ventilated seats to work simultaneously with the heat? That's one thing I have always loved about driving a Porsche.
swoop1156
USA
This one below. Listening to same song, There is a noticible difference in sound. Whether you like it or not depends on your personal listening preference of course.
So I did this a few days ago, and I also disabled the fake engine noise, and the ANC was already enabled on my truck but it definitely seems to be more potent, if you will, now.
The sound is more bass heavy which is alright, I might screw around and change the values since without looking I think it has about 15 different calibrations, but no description to what they all are. This is good for now.
Another benefit, for me at least, is that I somehow have also killed the turn signal sound. Was really annoying when I actually used it It still does it when I'm parked or stopped in D, but when actually moving, it's silent and the dash just blinks.
I read the spreadsheet some and couldn't come to a consensus on what to try changing to enable both the heated seat and ventilated seat simultaneously. I might try changing some random values and see what happens. @Antho any savior to my misery?
rms8
FORSCAN QUESTION :
hamster
Is there a way to adjust/disable the amount of time the radio stays on when you open the door after turning truck off? I'd prefer it turn off immediately when the door opens, just like every other vehicle I've ever owned. In my 2024 Raptor the radio stays on roughly 4 seconds or so once you open the door after turning off truck. In my 2017 Raptor, the radio shut off immediately.
Thanks
Antho
Adding heated and cooled seats to the touchscreen? @swoop1156
