GEN3 Forscan
ZorroV
Los Angeles, CA
I finally got around to reading now 124 pages (was a lot less when I first started this thread). I've had my MY22 for a little over 2 years now and just got around to messing with Forscan about 2 weeks ago. I gotta say the wealth of knowledge gained from this forum and forscan thread is amazing, Thank you!
Listed below are what has been done and what is pending.
Done:
-Double Horn Honk disable
-Enable Digital Temps
-DRLs - full brightness
-DRLs - include parking lights
-DRLs - allow fog lights
-Disable Fake Engine Noise
Pending:
-Turn signal blinker
-Enabling fog with DRL
swoop1156
USA
I did the audio mod. There is a clear difference. I prefer the new setting vs OEM
I recommend trying it.
Which are you referring to? Disconnect the center speaker or...?
Done:
Pending:
Disable fake engine noise? I gotta look that one up. Worth it? Also do yourself a favor and enable glare free!
CT
Since posting the above spreadsheet image, I have made some other changes and adjustments.
* Removed Bambi Mode since moved bumper lights up to Aux 3 & 4.
* Added the "4" to get all the digital temps available.
* Added 3 more IPC changes to get rid of the seat belt visuals.
* Removed Lincoln Autofold....prefer puddle light to work. Just using Walk Away Lock with OEM Auto Fold.
* Removed DRL with Fog Lights since moved bumper lights up to Aux 3 & 4.
* Added Front Fog Disable to turn off the fog switch since moved bumper lights to Aux 3 & 4.
* Adjusted the temp on the Heated Steering Wheel. Set to 98.6 degrees, but may move up some more. Will see when gets cold.
And while I am not using these, they may help others. Note Lincoln Mirrors has a new 2024 change.
Thanks for the updated information.
I'm confused by the right side of the updated screenshot now.
What's the difference between "Original Values" and "Factory Values"
hamster
Northern VA
Original Values are what was delivered with my Raptor which I both recorded in the spreadsheet and made copy of the file.
As I went along the learning path looking to disable my Fog switch, I looked at what was available for download from Ford for my VIN. That is when I learned that Factory Values could be different from what came in the truck in some cases. Hence why several people have posted to make a copy of the files before you change anything as you can't just go back to what you can download from Ford.
German_Potato
Bavaria, Germany
Greetings to you in Germany. This has been covered exactly before in this thread. It's many pages back and deals with a user in the UAE, where the amber surrounds are also disabled. I went around and around with him and we got it working. Please look back and read the entire thread and you'll find it. If I can find it, I'll link it to you. You shouldn't have to have DRL's (as we know it USDM) on AUX switches. That's wild.
Try starting here and see if this makes sense for you.
Are you able to give us your values specifically from FORScan? I'll definitely try this out.
If I am correct, the “fixed position” light is the DRL with 10% brightness.
Can this be coded to ALWAYS on?
I manage to activate the 10% light when the low beam is on, but I want it on as soon as the ignition is on.
Now I have the 100% DRL's on AUX, because this switch is quicker to deactivate when you see the police. In Germany, an orange DRL results in a €135 fine and one point (with 8 points, your driver's license is revoked ).
insangsong78
cali
This one below. Listening to same song, There is a noticible difference in sound. Whether you like it or not depends on your personal listening preference of course.
