GEN3 Forscan
Since posting the above spreadsheet image, I have made some other changes and adjustments.
* Removed Bambi Mode since moved bumper lights up to Aux 3 & 4.
* Added the "4" to get all the digital temps available.
* Added 3 more IPC changes to get rid of the seat belt visuals.
* Removed Lincoln Autofold....prefer puddle light to work. Just using Walk Away Lock with OEM Auto Fold.
* Removed DRL with Fog Lights since moved bumper lights up to Aux 3 & 4.
* Added Front Fog Disable to turn off the fog switch since moved bumper lights to Aux 3 & 4.
* Adjusted the temp on the Heated Steering Wheel. Set to 98.6 degrees, but may move up some more. Will see when gets cold.
And while I am not using these, they may help others. Note Lincoln Mirrors has a new 2024 change.
What about disable auto start/stop? I don't know if it's different for 2024, but it's not working for me when I made the changes.
hamster
Northern VA
As others have stated…I really feel we are at a point where a dedicated spreadsheet is needed for the MY24 Raptors.
That is a lot of work for @Livnitup and others that help him especially for a small subset of F150. And I have not seen too many 2024 changes and when they are caught they seem to get noted. But not my call....just trying to help where I can.
Antho
Like @hamster mentioned, There really isn’t a need for a separate sheet. I have given Livnup Anything that I found that would somewhat need to be on the common sheet that’s Raptor or 24 specific. Anybody else is more than welcome to create their own sheet and post it.
@vegasjunkie2004 Auto Start stop disable via Forscan hasn’t worked on the Raptor since 2021.
Thanks for the answer to my question! I've looked through so many threads and never noticed that. Thanks again!
FullSend
Colorado
I took a PTO day and sent the Fam on a mini vacation to read all 119 pages and what a roller coaster. I went from not knowing what Glare Free was, to absolutely planning to make that change, to being gutted when I found out its not available on the 2024's. Assuming that is still the case, but hopeful that someone figures it out someday.
hamster
Northern VA
Been there...done that. :signs8:
Old Grand-Dad
USA
Anyone figure out how to adjust the brightness/dimness that the auto headlights come on? I tinted my windshield, and the headlights come on/stay on too early/too long
Did you figure out a solution for this? I just had my windshield done and I'm seeing the same thing. I saw the question asked other places, but it doesn't seem like anyone found a solution.
