GEN3 Forscan
khildebr
Pleasant Valley
Hello,
I did this change but I still only have coolant temp and trans temp at the top. Oil temperature is just a needle without any values below it. Did anyone face a similar issue and got it to work?
This is for MY23
Edit: I found another change in the spreadsheet in 720-07-01 xxxx-xxx4-xx and it should add digital oil temp. Will try it and report back. This didn’t work.
This is unfortunately how it displays. No option has been found that I’m aware of in Forscan to make the number appear below the gauge even though you can see the number in the Measurements screen as you’ve shown. :mad:
CT
I literally just read all 114 pages of this thread. My brain hurts. Only to find out my 24 will not accommodate glare free. I was able to disable the 'door open triple chime' and 'startup triple triple chime' (which I cannot stand) in addition to other items that were listed above...
how did you get the startup triple chime off? Cant seem to get that working. Also any luck with the Start/Stop ?
*edit* figured out the triple chime.
tu3712
How did you get the triple chime off? The values on the sheet did not work for me. Thanks in advance
swoop1156
USA
My turn for a dumb question for @Antho and others... This is a nit-picky thing, though when parking, the DRL's are on and the orange surround (or however you have it configured) is illuminated. When we shift to park, the DRLs go off, because it's not PRLs, as in Parking Running Lights (my words in a previous post lol). Then, when we open the door, the DRLs come back on. Similarly, when we remote start, everything illuminates, then we push the ignition button and they all go off, only to shift into drive/reverse/neutral to have them come back on again.
Seems like a lot of unnecessary on and off all the time.
Is there a way to configure where they just stay on in Park as well but still shut off when the truck is shut down?
So I just had the idea to park and leave the truck in neutral while it is still running. I always use My parking brake so I had the idea If I opened my door and then turned the truck off, it will automatically go into Park. The DRL stayed on and I turned the truck off and all was right in the world.
I have a quick question about markers on my '24. I want to have the DRL's and grill markers on only (no rear tails). I didn't change 726-38-01 since I don't want rear tails and there is no change needed for 726-43-02. I did change 726-87-01 as shown below, but the grill markers don't come on-only DRL's. I read Suppress License Config was needed since the markers are on that circuit now. Why wouldn't mine be on? Thanks in advance!
Auto start/stop wasn't disabled when coded using forscan. I've used forscan previously on my 2017 king ranch and 2018 raptor and never ran into issues like this. any help again would be appreciated.
hamster
Northern VA
726-38-01 change will enable parking lamps to come on with DRL so pretty sure you need that config change. Easiest thing is to change 726-38-01 per above and if grill markers come on then that is needed and there may be no way to get all you want on with no tails.
hamster
Northern VA
@RaptorAU try 720-07-01 xxxx-xx54-xx-- That should enable the digital for Engine and Trans.
On the '24, you can see digital values for everything on this screen which is my default (default as in if turn truck off with this screen up, then it will come back to same screen). The middle two guages where I have oil pressure and oil temp are user configurable and all of the options have a digital value.
The "4" you suggested turns on eng oil tempurature on most screens (see below), but not eng oil pressure. I am in an R so I used xxxx-xA54-xx. An option is to configure MyGauges to see digital oil pressure if you want or use the Performance screen or Measurements screen. I could not find any setting that might turn on oil pressure at the top of these screens.
Hope that helps clarify a little. Thanks for the "4". :)
hamster
Northern VA
This document although dated older than what Livnitup's showed, had the missing stuff
I think it's time someone makes a 24+ thread
Since posting the above spreadsheet image, I have made some other changes and adjustments.
* Removed Bambi Mode since moved bumper lights up to Aux 3 & 4.
* Added the "4" to get all the digital temps available.
* Added 3 more IPC changes to get rid of the seat belt visuals.
* Removed Lincoln Autofold....prefer puddle light to work. Just using Walk Away Lock with OEM Auto Fold.
* Removed DRL with Fog Lights since moved bumper lights up to Aux 3 & 4.
* Added Front Fog Disable to turn off the fog switch since moved bumper lights to Aux 3 & 4.
* Adjusted the temp on the Heated Steering Wheel. Set to 98.6 degrees, but may move up some more. Will see when gets cold.
And while I am not using these, they may help others. Note Lincoln Mirrors has a new 2024 change.
