GEN3 Forscan
higherup
Oklahoma
lmao i literally just finished ******* with it..So out of pure boredom on baby leave right now, the setting for "Dynamic Bending" is in HCM 734-01-02 but disabling it will then disable glare free as well and put out a DTC for incorrect HCM config. tried to mess around with the "High Beam Handling" as well but still threw a DTC config error and disabled glare free.
oh well, I'll just keep living with it no big deal.
bored and finally figured it out.
if you care about Glare Free & having a soft code for incorrect config, don’t do these changes.
I personally don’t care about Glare Free and I really hate the dynamic bending. It was very simple change.
I changed HCM;
734-01-02 **xx-xxxx-xx to 00
734-01-02 xxxx-xx**-xx to 00
this will create a headlight system fault appear on the cluster.
you’ll then go to IPC and change Adaptive Headlight Feature to Disabled
that will clear the fault from the cluster but you will have that soft code whenever you load up FORscan.
this is on a 23 and obviously you assume the risks with changing stuff so be sure to back up your stuff just in case.
BoltedDesigns
Los Angeles
Has anyone seen this or made this mistake when trying to calibrate ride height on a Gen3 Raptor. I have tried several times to clear code but can’t clear it. I even took my truck to the dealer to try to get them to clear it. They said it could be my cluster module and ordered me a replacement. The truck will not allow me to put it into to neutral and ET at the same time without the truck running. I can not get it into the correct state to continue the calibration, assuming because of the DTC error. Any insight would be great.
JakeMate
Charlotte,NC
Did this Glare Free mod last night. Seems to be working although I am getting a message at startup about Checking the Headlight system. A quick question about the last line of code below with the 'HCM 734-01-04 xx56 D1--'. I believe mine read 'A1D1', not 'D1--'. With that said, I only changed the '56' in that line of code and nothing in the 'D1' portion. Is that correct? Am I supposed to change mine to '0056 D1D1' or '0056 D1--' with the 2 dashes?? Just need help with that last line of code.
You can see the DTC error in the last image. I tried clearing it but it stays.
Original Instructions:
HCM Question:
swoop1156
USA
HCM Question:
My suggestion would be change the last line of code to D1D1 regardless and let FORScan figure out the checksum for the end. For what it's worth, my stock values were "00F0 A1D1" (same as yours...) and my modded values are "0056 D167". Mine is a '22.
Antho
HCM Question:
The simple answer is to do the values that you where provided. @JakeMate
JakeMate
Charlotte,NC
Thanks @swoop1156
I changed it and the error went away. I haven't driven it yet to verify but I'll bet it's fine now. (Knock on wood).
WhiskeyTangoGTFO
SLC Utah
Here are my current changes and notes. Turn signal flashes at the end. Still messing with cameras at speed as I made the changes and it did not do what I wanted.....hence in yellow highlight and marked not tested. Everything else works on my 24 R.
I’m struggling with the cameras at speed as well in my 24 R
Were you able to confirm your settings by chance?
Mine had the F & D’s already but the C will change back to stock E every time.
hamster
Northern VA
Got distracted and have not figured it out yet. Took Lincoln Mirrors out today as don't like that it turns off puddle lights. Will stick with regular fold. Fixed few things on truck and going to realign rear bumper tomorrow. Will get around to cameras at speed one day sooner or later.....been hoping someone smarter than me would figure it out first.
:signs8:
WhiskeyTangoGTFO
SLC Utah
:signs8:
Yep same lol
