GEN3 Forscan
hamster
Northern VA
This is the the route I went to eliminate the seatbelt visual indicators:
I just wanted to stop the dinging (visual off would be a plus) as I always wear my seatbelt on the road. I just have a habit of unbuckling when start to back into the driveway and did not want it to ding at me.
HookEm
Here are my current changes and notes. Turn signal flashes at the end. Still messing with cameras at speed as I made the changes and it did not do what I wanted.....hence in yellow highlight and marked not tested. Everything else works on my 24 R.
I’m surprised the R has any fake engine noise. Did you notice an audible change after making this mod?
hamster
Northern VA
My seatbelt light will not go out.
So thanks to @Antho over on F150 forum, I was able to turn off the seat belt visual reminders. The first line of change below is from the master spreadsheet and took away the sound, but you stll had to hit the OK button to clear the large visual indicator and the little red man warning remained in the dash. Then @Antho posted the 3 additional changes and I added them today. Got rid of all visual indicators. However, it does leave a DTC that you can clear, but it will come back immediately. Not sure if the DTC is going to cause a problem somewhere else so be nice to have a fix. But at least now when I start the truck it goes right to my desired screen config and don't have to hit the OK button. Then I use the R button once out of the development and it has warmed up to go to sport, etc.
eanevarez
Las Vegas
Read through 109 pages and did a few changes on my 24. Thanks for the wealth of information!
Auto start stop delete
DRL with fogs
DRL with marker lights
Bambi Mode, Fogs with high beams
Disabled the start up chime
Change brightness on DRL to 50%
Removed the black box on camera view
Walk away lock
Audible walk away lock
Auto relock after 45 seconds
Double honk on exit delete
Door ajar chime delete only chimes when doors open in gear now
My cameras always worked at speed but still made the changes just in case as well as off-road cameras at speed
Oil life in sync settings
Increased turn signal flashes for lane change
Disable driver seatbelt chime it didn’t work ended up following the four seat belt clicks in accessory mode after airbag light shuts off.
I no longer get the red seat belt visual for my back seats I feel like I did in the past? I can only see driver and passenger. Has any one found if glare free is available on the 24s? There was a post for audible blind spot and a YouTube video is that just a myth tried it but it didn’t work.
Antho
DRL with fogs
Walk away lock
Glare Free does not work on the 24
alockbox
US
DRL with fogs
Walk away lock
I thought when I started reading this, you were going to say you collected them all here in your post! Any change you made note of them all to save us from the same fate?
eanevarez
Las Vegas
