GEN3 Forscan
Mike27t
It's absolutely available as I have changed mine to 4, because the 3 is actually 2 if you ever watch it, so changing to 4 makes it 3. I'm on mobile, but it's absolutely there.
Thanks for the quick reply. Yeah the default flash count is worthless imo.
I didn’t see it on the updated spreadsheet thus left me scratching my head. When you are able to, can you confirm the address to update is still 724-01-01?
swoop1156
USA
It looks that way. If you can do the hex, or perhaps find an old post somewhere... Or I can look at my actual values when I'm back at the office...
Mike27t
I’ll try to dig, but would appreciate any additional info when available. Thanks swoop1156
hamster
Northern VA
Hey Y’all, thanks for the thread and all the helpful info thus far. Coming from a gen 2 im familiar with Forscan and have been able to make some changes to my 24.
Looking at the updated Forscan code list for gen 3, I don’t see one feature I was fond of on my old car. The feature is called “Turn Signal Flashes (# of)” which allows you to change the 3 flash default value and was found in the IPC module.
Anyone aware if this is available for a gen 3?
Thanks in advance.
Here are my current changes and notes. Turn signal flashes at the end. Still messing with cameras at speed as I made the changes and it did not do what I wanted.....hence in yellow highlight and marked not tested. Everything else works on my 24 R.
JC Chaze
Spring Hill
The seatbelt ding couldn’t be any easier. Put the truck in Run without starting. Begin with belt unbuckled. Once the seatbelt icon disappears from the dash (~60 seconds), fasten and unfasten the seatbelt 3 times ending with it unfastened. The seatbelt light will flash. Then buckle and unbuckle one more time and you’re done.
Repeat for the passenger side if desired.
My seatbelt light will not go out.
swoop1156
USA
This is friggin cool! As I’m way late to the party, I have to do this on the gen 3 yes?
Complete noob on forscan…
You don't have to do it, but you absolutely should if you do any sort of driving at night. I'm taking a trip and electing not to take the truck and I'm already anxious about not having the GF lights (plus the rest of my AUX lighting) and I'm not even on the trip yet. It's that nice.
RaptorFun
Northeast Wisconsin
This is the the route I went to eliminate the seatbelt visual indicators:
