Gen 3 Common issues we are now seeing
IamNomad
Estes Park Colorado
2200 miles on my 2023 Raptor that I have had just over 3 weeks. One long 1465 mile road trip and the rest mixed driving.
The only issue was that the stereo system lost all bass response and what appeared to be left and right speakers.
The only sound audible appeared to emanate from the center of the dash board. After about a half hour it started to work properly again.
I was listening to Siriux/XM and did not think to try AM or FM so it could have been XM's fault but I doubt it.
No issue since.
taquitos
Seattle
3GF
Charlotte, NC
2023 Raptor here. Bought it last week. Yesterday at 293 miles on the truck I did a remote start and it started up running very rough with service engine lights on. It wouldn’t go over 8mph so I’m assuming limp mode. Turned it off then restarted normally and it was fine. Engine light gone. Took to the dealer and they saw a P2101 throttle code error had happened. Hasn’t happened since but then again it’s only been a day.
Funny, I had literally the same exact thing happen on Saturday. 2 weeks old, ~1200 miles. Just like you, turned it off, then started it back up, and everything has been perfectly fine.
Otherwise, it's been perfect, and I've tested just about everything so far. :)
Shinysideup
Ontario, Canada
Stalled going up a steep gravel incline in 2wd. Rear tires broke loose and dug in. I was trying to see if the Torsen axle would engage in 2wd, it did not. I just restarted the truck put it in 4H and crawled up. 200km and 1 day of ownership.
Not worried and probably not an issue, but I figured I’d share just in case.
Keith88
Boise, ID
torsen is up front and only on the 21 & 22 Gen3s.. its limited slip in the rear till you turn the locker on... idk could be wrong
