Gen 2 SCAB rear end kicks sideways over bumps??
Ocotillo Boy
Ocotillo Boy
Will these fix the sideways kick?
rtmozingo
North Texas
Partly due to tire pressure, partly due to tires. I aired down to 28 in the rear this weekend and still broke them loose quite frequently in the dirt.
Light back end, high torque. Nature of the beast.
Heeblet
Tire pressure. Do that first 37 front 35 rear then report the results. Ez to try.
Sent from my iPad using Tapatalk Pro
jaz13
1) If you require a planted rear-end, you shouldn't drive a pickup.
2) Slow down
3) Reduce air pressure
If you don't like the above, learn to live with a loose rear end.
4) Don't react to the stepping out and the truck will sort itself out just fine. Most crashes are caused by drivers overreacting, not under-reacting. This is a stable truck and it wants to go straight if you let it. Learn to trust the truck and these minor steps-out will stop bothering you. They are only an issue if you make them an issue.
5) Learn to drive a vehicle with a loose rear end and embrace the oversteer. If you really get on it, it only takes small inputs of counter steer to correct a minor slide and it is a ton of fun driving with the rear end leading the turn-in.
