Gen 2 SCAB makeover…totally not ripping off Geoff’s 2.5 build!
mashtastic
las vegas nv
It’s a an Asian knockoff of the SPD with the same issues I pointed out above - and slightly worse fitment. Sorry if this comes off harsh, their r&d process consists of Rob & Duplicate so i don’t hold back
so port the SPD's to match the Garrett's is the perfect option? Have you tested the ported vs no ported on the dyno? personally, I am not looking for high hp numbers, just reliability with quality parts. with everything we've talked about within the two threads, I am estimating north of 600 hp with a lukewarm tune...which is fine going to dunkin'.......the lonnnng way
Sorry Eunos, you can have your thread back
91Eunos
91Eunos
Hill country, Tejas
Baby steps… got the RH side motor mount nuts removed, and have the radiator draining:
As soon as that’s finished, I’ll lower the truck and remove the battery. May as well get the radiator grill, radiator, oil cooler, etc. removed today too.
91Eunos
91Eunos
Hill country, Tejas
Battery, air filter assembly, etc. out and almost all connections disconnected…
But having a hell of a time getting the heater lines going into the firewall disconnected for some reason, so gonna call it a night before I get frustrated.
These little bastards:
Edit: Think I figured it out, but will need to get someone over to help. The manual shows to push in on the tab, and then pull the hose out from the firewall:
…but there are two tabs that need to be pushed in simultaneously, and they’re located 180* out from each other. I think I can have the truck lifted a few feet off the ground so someone can get underneath with a really long screwdriver (I have one) to push the bottom tab, and I’ll stand on a ladder to reach into the engine bay and push the top one.
There’s probably a special tool for this, kinda like the transmission connector, and fuel line tools, but not sure I need to buy a special tool for what I hope is a one time use.
