Rebuild of what?
I haven't gotten around to the fronts yet but I too suspect that between the longer body and limiting straps, travel will be limited there as well.
I bought this set of Gen II shocks for $650 and they're basically brand new, so losing a bit of travel may be worth it to some people. I was looking at Deavers in support of a Whipple anyway. Someone correct me if I'm wrong, but from my limited research, it seems like Deavers+Gen IIs would be a nice upgrade on the rear and may even gain a bit of travel?
+3 deavers with rpg +2 shackles give more rear suspension droop. (Its more than an inch.)
That combo also gives stock rear height
I actually want a bit of lift as well because I'm losing the compression travel with the taller bumps.
I don't think there's a good way to get a bit more droop and lift out of the front, is there? I recall CVs may be a limiter. I'll probably take one out to be sure, but I think the fronts will be losing ~1" of travel.
