Gen 1 Spare Tire Hoist Wanted
Jhollowell
Everett, wa
Ok....Tthey look similar the 14 will not fit on the 11 I am 100% sure if this.
This one is off my 2014 frame. the bolts are offset. To the hooks
this is the one for a 2011 bolts are not offset to the hooks.
The plate could be modified to fit. I would think but there is a difference.
and YES @MurderedOutSVT @Nex I get Reesie Cups in a tub!!!!!! LOL
Is this the only piece to the spare tire winch? I'm putting mine back on but i found another bracket in the "raptor parts bin" and don't know what its from.
Gumby
Nashville
Well... The piece that It mounts to, but that is welded to the frame. so.... I doubt you cut that off. Here it is. The piece between the back and mid crossmember. LOL NO further Questions!!!!!!! LMAO...JK
Gumby
Nashville
I guess I did't really finish my thought. There is the little funnel piece that goes on the bracket to the hoist. That helps you find the end with the crank. (for rase and lower) I think that is it.
Jhollowell
Everett, wa
Yep. I have those two parts. The mystery part is a bent bracket thing. Looks to be about 1/4” thick with a few holes. Maybe it came off when i did the frame cut front bumper? I haven’t removed much else except that weight on top of the frame. I should label stuff when i remove it and not just throw it in the bin labeled truck parts
