Anyone doubling up spares on flat bed spare tire racks like JDS or KHC? Or have a chase rack recommendation that could fit under a Retrax cover?
md270raptor
md270raptor
Maryland
Just completed Midwest Offroad Expeditions' "Wendigo Watch 2025" this past weekend, and had to 37s strapped into my bed, and they didn't move an inch I also have been on many Silver Lake Sand Dunes trips, with no problems there either. I too like running a tonneau cover, along with using my bed often for dirtbikes, and just hauling stuff in general. I took a piece of 1/4" steel, and traced part of the circumference of the tire onto it, ground it off, and then, used angle iron, and welded it to the plate. I then drilled holes through the bed, bolted it down, and voila. It works well.
Now, after some note taking, and running this setup for a little over a year now, I have come up with a better, sleeker design.
I will be throwing that chunk of steel that I made away, and instead of the angle iron on top of the steel, I am going to get some flat bar and bend it to match the shape of the tire, then weld that directly to the plate. I will be then flipping it around, keeping the same strap orientation, but also then removing the tie down point, and welding a tie down point to the bed support. This way the tires are further towards the rear of the truck more, and will be held tight against the "mount" on one side, and the bed support on the other. Hope my DIY experience helps!
View attachment 485070View attachment 485071View attachment 485072View attachment 485069
Much appreciated insight and nice job on your rig. This is exactly what I was wondering if it was possible or not. I sense I do your approach with the JDS Customs route (not as handy or have the tools available for DIY) and then when I have money to burn step up to the 454 Motorsport rack which looks sweet but definitely has the Raptor tax attached to it.
SilverGen1
Midland MI
I would really like to see someone make a tire gate, where you can still run the tailgate, but something that has a bed support, with a plate that extends into the bed with a cradle for two tires be strapped flat down, then a pin system that you can pop the tailgate and swing the tires out and still have access the rest of your bed, or easily able to get in and out of it. I definitely see the attraction to the behind the cab vertical tire mounts, but the more weight towards the rear of the truck you can get, the better!!
Jr Jr Offroad
Cave Creek, AZ
That looks like it would work perfectly. Thanks for the link.
May have to order one and pick it up on my way to Sedona.
You will be very pleased with Trevor’s work. I ran his removable carrier on my tundra- and now I am running the bolt in carrier on my raptor. I chose bolt in this time around cause I never actually took the removable one out.
QCRappy
Charlotte, NC
How do you like it? Was thinking of going this route.
It’s good! I like it very simple and functional. Only thing I wish more would be a powertank mount somewhere. Could end up going to a 454 removable rack but who knows
scottp6188
chicago
yeah, theres previous threads about it, butnyou are lucky enough to not get hazed for making a new thread. its far and few inbetween. i have a chase rack that holds a storage compartment for my tow straps and air hoses. has a second battery location. holds my 4 air compressors, a tool set, 10 gallons of gas (2 5gallon cans) a spare, an air tank, and a jack. i keep one spare in the oem location. this allows me to still run 2 spares and also close my bedcover. i have the revolver x4s.
Probably a stupid question, do you think the stock suspension compresses enough when jumping to land and hit the spare in the OEM spot? I want to run this exact setup but also want to jump it this year.
QCRappy
Charlotte, NC
not unless you really dukes of hazzard it. The rear has factory bump stops thatll contact. I jumped mine with other RPG/foutz levels and smartcap + 37 km3 in factory spot and didnt hit
The Car Stereo Company
here, on frf
you need to run an aftermarket bumpstop kit. otherwise you run the risk of bending/denting your frame at the oem bumpstop location. with the setup, you add probably 400lbs to the bed, so big jumps could cause damage under full compression. i have a specialized 13 leaf spring pack and a bump stop kit.
here, on frf
these are the only photos i have at the moment. they were taken with my old phone which had camera issues. but it holds 10 gallons of gas, my tool kit, 4 air comprssors, a second battery, storage compartment for my tow straps, air lines, etc and one of my air tanks. i have 4 air tanks as well. also has bed supprts. i keep my second spare in the oem location. but its all tucked away and under my bed coverIMG_20181224_215455869.jpgIMG_20220806_122340.jpgIMG_20181230_161707023.jpg
