Gen 1, hill descent control fault, service advance trac, check brake system
gusser
Connecticut
Really surprised your 3rd brake light wasn't the culprit - are you able to swap the unit out with another one (got a spare or maybe even junkyard or aftermarket?). All those symptoms were definitely screaming "3rd brake light," the price of a new OEM 3rd brake light skyrocketed several years ago, wonder if they're even still available...
My 2011 Screw's light was badly faded as my Gen1 was a work truck and spent most of it's time outside. I also have the rusted cab corners and the stains on the headliner due to the seal failing. I replaced it with this Morimoto B-ASY-X3B20-MM option.
Looks pretty good on my Tuxedo black Gen1... :happy107:
The gasket is very thick too and should keep it's seal for a long time, although she's a garage queen and won't see too much sun except when I drag my jetski to the lake or haul my RC aircraft to the flying field.
I ponied up the extra $25 for the flasher module. works great. Not sure what a new OEM replacement is now, but for $225 I feel it's a better option.
Good luck with your repair.
:cheers:
Bozz
Royal Smart A$$
Nashville, TN
:cheers:
I have the same one, also with the flasher module. Very happy with it and it looks GREAT.
