Hill Descent Control Fault AND Service Advance Track acting up
whitemtr2000
san Ramon
Okay, I know this is a known issue and I’ve read (I think) most posts and threads about this issue.
Since I’ve bought my 2012 gen 1 raptor i have gotten the hill descend and service advance track codes to throw every time I steer max left or right and am going forward or backward while steering.
I’ve replaced:
The clocks spring (twice - since I thought I installed it wrong first time)
Steering position sensor (twice - for same reason)
And today I replaced all four abs sensor
New 3rd backlight - (aftermarket)
What am I missing here? Do I just need to live with this issue? Driving me crazy!
Dain
Pensacola, FL
That truck is a little older than my Super Duty (its a '19) but I dealt with this issue for awhile myself. The pitman arm nut came loose and cause some play in the steering wheel before the wheels would actually move. Go through all of your steering linkage and make sure its all tight. For this issue I had, there was a discrepancy in the steering wheel angle vs wheel speed. If the wheel is turned the truck expects wheel speed to be a tad different between left and right. Worth looking into.
whitemtr2000
whitemtr2000
san Ramon
This definitely sounds like a possibility. When I got it strangely enough, one one the sway bar linkages was bent - never seen it before. There might be more off to your point..
Dain
Pensacola, FL
Like I said, its worth looking into. In the super duty groups it comes up a bit and as weird as it sounds, a lot of times that pitman arm nut or some slop in the front end linkage is the culprit. Wheel speed sensors or the wiring going to the sensors is another popular issue causing the lights. One last thing I can recall was some electrical connector in the rear of the truck getting wet/corroded.
