TXRaptor
- Joined
- Sep 15, 2010
- Posts
- 1,851
- Reaction score
- 1,047
Here is the amount I had to trim on both sides. It was done in about 5 minutes with a grinding wheel.
I will clean it up after I get a chance to remove the tires next weekend.
I finally got a free moment to clean up the inner fender trimming. At first, I trimmed the plastic following the curve of the liner. This removed the part which sticks out the furthest. I painted the part behind the liner with flat black paint to help it blend in with the inner liner.
After moving to the right side, I could see where the tire had rubbed on the edge of the fender flair while doing some off-roading last weekend in the hill country. It only happened once when making an abrupt turn up a steep incline, but I decided to trim the same spot on both sides just to be safe.
I also painted the wheel hubs on all four so I could remount the wheel/tires without using the Fuel center caps with the big Chrome "F".
The first trim picture is before I cut the edge of the fender flair and the second picture was after I cut straight down following the same line as the crease in the inner fender. Someone asked on another thread about the cutting tool, so I snapped a quick picture of the Dremel Micro.
