GBrown 1867 Build
GBrown1867
GBrown1867
Nor Cal
Why never in 4wd??
Sent from my iPhone using Forum Runner
I prefer the way it handles in 2wd. I can drift the turns and for me its more enjoyable to drive. I will use 4wd to get moving in soft sand or sometimes in sharp rocks to help save my back tires. But overall I rarely use it.
E63
Poway, CA.
Wilson. I had offroad mode on and the traction control off. Was in 2wd with the rear diff locked. This is how I always drive my truck offroad.
Plus manual shifting to keep the revs up!
Why never in 4wd??
Not nearly as much fun, can't easily drift the rear (thru throttle modulation) on tight turns. I only use 4 WD when bogged down.
Wilson
South Dakota
Did all of sdbr in two wheel with the week iwe I try and save it for when it's really needed. I wish they'd get it worked out.
sonoma
Dispatch
FRF Lady
California
Try drifting turns in 4WD and you'll see the difference between 2WD and 4WD....it's like pulling teeth in 4WD taking turns
Bigg50
Benicia, CA
I've usually ran 2wd but 4wd is a bit safer. I had the wife with me this past weekend and hit a hill at about 60 mph, only 1 of the tires had traction so it pitched the truck sidways a bit. I corrected the truck but it was a bit scary. Well, it probably wasn't that bad but I think worst case these days because of my incident and Gordon's.
