Gas mileage dropping, worried something mechanical.
cddawgs
cddawgs
Macon, Ga.
Calculated. I wasn’t university material but this I Can do. Dash has changed from 14+ only once and that was to 16. Wierd. But calculated has been a steady decline.
Two Dogs
Fisherville, TN
I don't know for sure on the raptor, but the first place I go when mpg tanks is plugs. Plus its easy to check.
Edit: Did you check/change your air filter? These turbos like to feed.
SL75
Toledo
That is a good point. Spark plug change will probably fix this. Curious what the stockers look like.
cddawgs
cddawgs
Macon, Ga.
filter and plugs clean. Dealership said the engine is still "breaking in" and mileage will vary till around 10. Wondering am I enjoying the turbo gauge a bit much? Oh well, thats why they put em on. I appreciate everyone's responses. I'll come back in about 2 tanks and let y'all know.
xrocket21
Maine
change your plugs!
edit: 5k miles only? Hammer on that bitch and clean the carbon out. When was the last time you hit redline?
cddawgs
cddawgs
Macon, Ga.
know what?? You got a point. Gonna hit a long stretch of 475 in a while, I'll air it out. But I got scared around 110 and it Has been awhile.
EricM
OHIO
Might be brakes dragging, or the wheel bearing as mentioned. A bad unit bearing on my SHO cost me 3 MPG.
