Gas Grade...
Wilson
South Dakota
I think I've gotten 25 but that was 55 mph or less maybe a bit of 65
---------- Post added at 12:23 AM ---------- Previous post was at 12:21 AM ----------
you would think going out to the hills would be up and coming home from the hills would be down
Cleave
Oxnard, Ca
my 22.1 and 20.8 was 65-75 mph, I don't know what the total elevation change could be, I don't live there
Wilson
South Dakota
ya but that was still a full tank
---------- Post added at 12:41 AM ---------- Previous post was at 12:39 AM ----------
ok you had 22 or so miles on that tank
Cleave
Oxnard, Ca
I've never noticed much of a difference between a full tank and an empty tank in my raptor, pretty sure that 22.1 started on a full tank, I think that 20.8 started at 3/4 tank or more considering the mileage to E was still based on the 11.6 avg mpg that was on the meter before I reset it
Cleave
Oxnard, Ca
lol, I actually get like, 490-510 miles to a tank before I fill up, which is when I get to about a little less than an 1/8 tank, my miles to E doesn't believe I can go as far as I actually can
Droid
kglesq's Brother
I've always run 91. My figuring is that the increased octane lets it run more timing across the board, given that it has an octane sensor and apparently makes significant use of it.
More timing is more efficient. Both 87 and 91 contain the same amount of energy (i.e., "BTUs"), but with 91 you can apply that energy better by starting the combustion of the fuel with the piston at a more efficient position. With more timing, you can get more rotational energy down the crankshaft for a given amount of fuel.
I could be wrong in this, the timing could be the same for 87/91 at non-WOT/closed loop. It could also be that the ideal timing is the same with 87 and 91 at the lower-load conditions when one is driving economically.
I thought I observed a slight increase in MPG with 91 as well, but that wasn't exactly scientific, and like every such non-controlled test, has a huge chance of being grossly inaccurate. It being a bit warmer or windier on one test versus the other would invalidate the results.
CraigBarish
Ontario, Canada
Anyone tried octane boosting? You can get tubes of Octane from any general outdoors store. I do it on my Sea Doo because none of the marinas have premium.
