more progress and pics from the Gen 2.5-
My absolute favorite oem brake rotor and pad is Raybestos r300 rotors and their ceramic pads:
BUT we discovered an oops when the wheel is tightened on the lugs. The gen 3 wheel bearing is so much larger that the wheel bearing ‘mounting ears’ to the spindle will rub on the Raybestos brake rotor ID when lug nuts are torqued (fyi I don’t know if all pre-2020 rotors will rub like this on a gen 3 rap )
so I barely gently trimmed the wheel bearing mounting ears to give the Raybestos rotor hat the room it needed to spin freely under clamping force
Next I cleaned the firewall with denatured alcohol to remove any grease. Then I carefully applied gold heat-rejecting foil. This stuff can drop temps 600F across 3mm air gap. It is incredibly tough and also firmly holds together the aging firewall insulation on this truck.
Slightly unrelated - we needed an extra gen 2 mockup motor in the shop so I got a junkyard motor and for fun I tore it down. I was appalled to see they installed a metal oil pan without changing the pickup. This is the 2nd time I’ve seen this, atrocious mistake that blocks and dents the oil pickup tube:
