FS Gen 1 Front Diff, Driveshaft, RCV Axles
BigGriff023
Rancho Cucamonga, CA
I have the front diff, front driveshaft, and RCV Axles I would like to sell. Removed it all when I converted my truck to 2 wheel drive after about 56k miles. Would like to sell it all together, but would consider selling the RCV axles separate. Local pickup only to Rancho Cucamonga, CA. $550 for the drive shaft and front diff, make me an offer on the axles. 8F42FC5C-D12C-44D0-AC52-6B2B99278F09.jpegFAAC094A-F47F-4C61-9623-00166FCA7664.jpeg7B76EE79-51FE-4B45-9A60-0665AF5921C3.jpeg
It’s a 2012. They are the orange end RCV axles that you can buy to run with the RPG Bolt Kit. I can take pictures of them if it stops raining. I have them covered up in the backyard, so I haven’t gotten around to it.
eh might not work for me. looking into them more and they are pretty pricey. i was just looking to get a spare replacement set
RallyMoto
Northwest Oregon
I believe it is since the 2012 raptors came stock with it. However, I’m not sure if there’s a way to tell by looking at it?
A VIN lookup? Or Ford should be able to tell you/me with the VIN based on as-built associated with it. I'm happy to call Ford if you feel like sharing the VIN. I'll research if there's another way. Pretty sure if you turn one side and the other side turns the same direction at the same time, then it's locked. That works for the rear anyway. I'd like to verify with the VIN if possible.
RallyMoto
Northwest Oregon
yes, 2012 and up came with the torsen front diff. not sure if it fits a gen 2 though
I know the axles work in both generations, I just need to verify mounting locations for the diff itself. Thanks for the heads-up on the Torson. I just saw it was an "option" on gen 1's. Write-ups and spec sheets I can find online show it first became an option in, 2012, not standard.
