Front Suspension Rattling Sound
Bowewelding
I had the same problem..I've mentioned it in recent forums..crazy rattle..i still have a tiny one I can't find but yeah the brake pads will drive u nuts!!
Denvertaco07
Denver, CO
I finally discovered what my rattle was. I was missing a brake pad anti rattle clip. The fix was less than $1 and easy to install. So, every time I went over a small bump the brake pad that was missing the clip would rattle. Sanity has returned!
autozone had them in stock and thicker metal than stock!
nice, thanks for the tip, i'll give it a shot.
Booth9999
Idyllwild
I’m having a front end rattle as well, I’ll have to check out the brakes.
Romans9
Also have some sort of rattle. Sounds like I'm dragging metal under the front axle... Only happens between 10-20 mph in 1st or 2nd gear...
JohnyPython
Canada
Check to see if your front anti sway bar end links have any play in them.
Rattle at low speed over bumps.Mine were replaced.
MarkM75
Las Vegas
Hello all. I'm a new Raptor owner and was experiencing the front end rattle being discussed here. I live out in Boulder City, Nevada and lets just say I drive the truck very hard out in the desert. I've jumped it multiple times and need new tires after 6,000 miles. I recently noticed the rattle, and as noted by other folks, the sound just wasn't acceptable for such a nice truck. After going to multiple dealerships and other speed shops in town, it turns out the brake pad on the drivers side was loose and rattling as described above only on speed bumps, potholes, and washboard dirt roads. I had a technician remove the wheels, the brake calipers, the rotors, removed all heat shields and skid plates to check for loose rocks, and also replaced both sway bar end links (this wasn't necessary, but I didn't want to be given the runaround by the dealership). By process of elimination, it turned out the brake pads were loose. He removed them, cleaned, and adjusted the clips. Everything is good again!
