xxaarraa
Southlake, TX
Anyone use forscan to turn up the voltage on the heated steering wheel? I did that today and set it to 100 degrees, but it doesn't feel any warmer.
AvoidTheBoyd
Wisconsin
I think the Raptor already has the steering wheel turned up to max by default. Look at line 11 in the HSWM on the spreadsheet. It is "full hot" and that is what my as-built is set to as well.
xxaarraa
Southlake, TX
Look at the actual voltage lines beneath that. "full hot" is only 88 degrees. There are two more settings above that - 94 and 100. Interestingly, mine was set to 94 as a default. I turned it up to 100.
AvoidTheBoyd
Wisconsin
Right you are, it appears, I wasn't comparing all 10 digits. I seem to remember this from another post that also said it was at max because of the thicker Raptor steering wheel, but that may been erroneous also.
Livnitup
SoCal
Tretiak30
Cleveland, Ohio
Way too many pages to go through but pardon if this has been addressed before..
What is the values to add the temp. degrees on top of the Instrument cluster on the 802A?
AvoidTheBoyd
Wisconsin
On the first page of the spreadsheet under common. Shouldn't be hard to find.
"Engine temp & Transmission temp shows above gauges (8"" Clusters only)"IPC720-07-01xxxxxE5xxxxx** use this if you have trailer brake controller **
IPC720-07-01xxxxx65xxxxx** use this if you don't have trailer brake controller **
Sent from my SM-G950U1 using Tapatalk
Tretiak30
Cleveland, Ohio
Well.... there it is. My mistake.
