Livnitup
SoCal
New 2018 raptor owner here needing to make some changes in forscan. Have no idea where to start to be honest. Living it up I been trying to find your tuturiol in your signature but don’t see it for some reason. Any of you all in Colorado Springs by chance? Recently picked up a 801a truck and added factory kicker sub with amp but isn’t working. Apparently have to make some changes in forscan and need guidance on what I need to change. Appreciate anyone that can help set me in the right direction. Thanks
Here's the tutorial: https://docs.google.com/document/d/1-8dKaS_Spu4Zw4hV_CrKC4tLoP9G8yejqegF1wxIqxY
Livnitup
SoCal
I did the auto start/stop, double honk and steering wheel heater icon. I can't seem to be able to do the temp above gauges. According to the guide the address should be 720-07-01. Checked every module and I don't see any numbers that start with 720. Am I some how missing a module ?
You're missing a bunch of modules because you're either a) using the wrong adapter or b) don't have it configured correctly
From the FAQ in my tutorial:
  1. I bought a USB adapter with a toggle switch but FORScan only finds a few modules. How can I fix this?
    1. go into FORScan settings, connection tab and change "MS-CAN Support" to "HS/MS Switch"
    2. connect to your truck again in FORScan but click no when it brings up your VIN profile (the toggle switch needs to be in the HS-CAN position when you connect)
    3. it should then find a few modules and then prompt you to flip the toggle switch on your adapter and find the rest of the modules
    4. if it finds all modules then you can save this new VIN profile and use it on all subsequent connection attempts.
TK85
Great thanks! I went in turned on kicker subwoofer and disabled fake engine noise. Can anyone tell me if it was necessary to disable engine noise?
Yes that engine noise was putting a lot of “white noise” through the stereo. Mine made a hissing noise that could be heard when the volume was low.
Honinspire02
Colorado
Actually trying to get as built codes from just a vin. I checked out Etis and motocraftservice but wasn’t able to pull codes. I’m mainly interested in acm as built codes from this vin: 1FTFW1RG7JFC78715
Appreciate anyone’s help!
Livnitup
SoCal
You input the VIN on this site: https://www.motorcraftservice.com/AsBuilt
Note: the first time you visit the link above you'll have to set your Country until a cookie is set, then you can click the link above again and get to the VIN input page. The ACM values for this VIN (1FTFW1RG7JFC78715) are as follows:
727-01-01 1809 1A08 0073
727-01-02 0A45 80
727-02-01 5B8C
727-03-01 1446
727-04-01 0001 0155 53DD
Honinspire02
Colorado
727-01-02 0A45 80
727-02-01 5B8C
727-03-01 1446
Thank you!!
RivRaptor
Rancho Cucamonga, CA
I would just like to say to anyone thinking about doing this that I'm glad I put the effort into making these changes with Forscan. No more engine noise, no more start/stop, numbers above gauges, no double honk....etc. Love it!
