2F150
Forscan is awesome.
Does anyone have experience with window tint and the automatic headlamps?
In particular, is there a value to change the threshold for the lights to turn on? I found information on the turn-on delay, but i want the lights to come on when the cab is darker.
Looking at 726-26-01 does anyone know what the Duty / VRMS stands for below? What is cornering?
726-26-01 x*xx xxxx xxxx Ambient Light Sensor Present Cfg: 0=not present, 1=present
726-26-01 **** xxxx xxxx
Ambient Light Sensor Type Cfg: 0=Slow_FNA, 1=Fast_Row
0=15 seconds delay turning on headlamps when dark, 1=2 seconds delay turning on headlamps when dark
726-26-01 xxxx x*xx xxxx Cornering Present Cfg: 0=disabled, 1=enabled
726-26-01 xxxx **** xxxx Ctrl Stop Position Cfg: 0=Duty_Duty, 1=Duty_VRMS, 2=VRMS_Duty, 3=VRMS_VRMS
726-26-01 xxxx xxxx x*xx
DRL Conditions Cfg: 0=Option A, 1=Option B
Option A=headlamp switch must be in Auto position for DRLs
Option B=headlamp switch can be in any position for DRLs
evan9r
Any other way to enable noise canceling and fake engine noise? I tried restoring the entire ACM module but no luck. Seems like it may have got turned off when I tried the Kicker speaker option.
Edbert
Austin, Texas, Ya'll
Thanks for the response - what's the code to JUST display the heated steering wheel on the home screen? I dont understand why ppl want the heated seats messing up the home screen when there are physical buttons in just the same amount of reach.
I know this is an old post (I just ordered my ODB tool and am trying to learn this by reading old posts) but I think it may be important to note that my 2018 (built the last week of the model-year) already has an icon for HSW on the home screen.
FORZDA 1
Gloucester, VA
I know this is an old post (I just ordered my ODB tool and am trying to learn this by reading old posts) but I think it may be important to note that my 2018 (built the last week of the year) already has an icon for HSW on the home screen.
Mine did too with a Jan 2018 date.
Livnitup
SoCal
If you restore your original saved ACM values then the fake engine noise should be enabled. Did you add an aftermarket sub? If so, you should be using the advanced programming method instead of the easy method that is likely turning off the fake engine noise with the kicker speaker option.
mmayo
Forscan is awesome.
Did you get a response on the auto headlamps? my windows are all tinted (even front w/ clear) and the headlamps come on often.
evan9r
I just added a DSR1 that does away with the Sony amp so that might be the case. I just thought I noticed the fake engine noise gone before I did the amp install.
DF105
San Francisco
I have made many of the most popular mods. They all work great with one exception. The Reverse Tilt Mirror is not working at all. I saw in the notes column that the 2018 may need FCxx for 740/741-13-01, so I tried that with no better results. I went to the link in the notes column for proper adjustment, and followed the instructions. My mirrors do not move at all when I put it into reverse. Any ideas??
2F150
Nothing yet. To be honest I haven’t even tried. Looks like I’ll need to step through changes to the file and experiment. I’ll can also do more research. Just returned from raptor assault, I’ll have some time in the coming weeks. I’ll post here with anything of value.
Did you now that the front camera is automatically displayed below 15mph in rock crawl mode? Truck is a badass.
waveslayer
CA
Any one know how to get the doors to unlock once I place the truck in park?
And yes, for all the internet ninjas, I can hit the unlock button, but in America I don't have to... so I would like to unlock my doors when I put the truck in park
My wife thinks I only have 3 guns
