I just restarted everything and coded :
drl - parking lights & turns only
bcm 726-45-01 xxxx 7fxx xxxx
726-26-02 x1xx xxxx xxxx
726-50-01 08xx
Not sure if it's working ... are the lights suppose to turn on when you first turn the car on? All my lights are off
Originally Posted by bfr View Post
That's called Parking Lights Only I believe.
Parking Lights only (stock LEDs only)
BCM
726-50-01 01xx
and I believe to get the change on line 50 you have to do this on 45 prior:
726-45-01 xxxx 7Fxx xxxx
As noted earlier in this thread, I had issues getting some of the DRL settings to work on my 2018...and concluded that what I wanted (Parking Lights (stock led position lights, grille and bars) and low beams) was actually the default configuration on my 2018. I never bothered going back to As Built to test, but no one ever confirmed or refuted it either. Perhaps you could confirm that for me since you have a 2018. What is your default DRL value (assuming you've turned it on in the Instrument Control Panel)??
I'm not sure how many 2018 owners have dug into FORScan settings to either confirm that the DRL settings work as the spreadsheet says or not...especially for the first 2 settings listed (stock LEDs only and stock LEDs plus Low beams).
RE: Auto Relock...you're talking about the case where you unlock the truck using the key fob but then you never open the door...so after 45 seconds it relocks the truck? I can confirm that the FORScan changes that are noted in the spreadsheet to NOT work on 2017s...also DO NOT work on my 2018. [the changes at 726-15-02] I don't know if anyone has found another way on 2017s and 2018s...but that change did nothing noticeable for me and certainly did not enable Auto Relock. So I returned the value to As Built.
Was just reading some of the other tabs in the spreadsheet. On IPC-new there are settings at 720-01-01 that are required for Auto Relock. Namely xxxx **** xxxx where * has to be a 4-7 or a C-F. I did not test if that made a difference (or if my As Built already had one of those values) when the changes at 726-15-02 were also implemented.
I have a 2018 Screw.
I made the following changes:
Start/Stop Disable
DRL - Parking & Low Beams
Lincoln Mirrors
Temps on Gauges
Heated & Cooled Seats / Heated Steering Wheel Icons on Home
TPMS "Specified"
Double Honk
After making the changes I noticed my Interior lights would pulsate continuously while illuminated. About a 1 sec rate.
A couple of days later, I reverted 726-50-01 back to the factory setting and wrote it. The pulsating stopped immediately. Tested it with the door open for several minutes and it never pulsated again. Closed the door and let them go out for over an hour. Came back and retested with the door open and it never pulsated.
I then reverted 726-45-01 & 726-26-02 back to factory. I have not had the pulsating interior lights after reverting 726-50-01.
I believe the change to 726-50-01 is not compatible with the 2018. I am not sure of the configuration of lights on 2018 DRLs. Weather has been so crappy that the headlights are on while driving during daylight.
