Dalejbrass
Anyone in or around Jacksonville, FL that can help me out with Forscan? I have all the stuff, it's just not working right.
Need someone who's done this before to guide me a bit.
Thanks
Dale
Derail
I'm just getting to this for the first time. I will figure out how to do it but do you have a list of the codes you implemented in your 2018?
Thanks!
Use the spreadsheet, some things vary depending on your installed options.
Be sure to back up all "As Built" files before changing anything.
But, here is what I used.
Start/Stop Disable
BCM 726-48-02 x0xx xxxx xxxx
Lincoln Mirrors
DDM 740-03-01 x8xx xx
DDM 740-12-01 Fxxx
PDM 741-03-01 x8xx xx
PDM 741-12-01 Fxxx
Temps on Gauges
IPC 720-07-01 xxxx xE5x xxxx (Turbos & Brake Controller)
Heated & Cooled Seats / Heated Steering Wheel Icons on Home
APIM 7D0-01-01 xxxx xxxx x6xx (Sync 3)
TPMS "Specified"
IPC 720-04-01 xxCx 2626 xxxx ( C=TBC Gain enabled & TPMS Specified Value enabled) (2626 = 38 Pounds front & rear)
Double Honk
BCM 726-41-02 xxx0 xxxx xxxx
bigzaj
What is the typical time to get Forscan forum activation? I have been waiting all weekend to get an extended license version!
ukantwin
do you have the codes for running DRL with all the amber?
Start/Stop Disable
Lincoln Mirrors
DDM 740-12-01 Fxxx
PDM 741-12-01 Fxxx
Temps on Gauges
TPMS "Specified"
Double Honk
joegie
North San Diego
DRL - Parking Lights only (stock LEDs only)
BCM 726-26-02 x1xx xxxx xxxx
726-50-01 01xx
DRL - Parking Lights & Low Beams only
726-50-01 02xx
DRL - Parking Lights & Turns only
BCM 726-45-01 xxxx 7Fxx xxxx
726-50-01 08xx
i'm using the first option on my 802A
here's the direct link to the spreadsheet
https://docs.google.com/spreadsheet...iVSlDFGFHnfeuhb3RTMVz95730/edit#gid=815852466
ukantwin
joegie
North San Diego
ok having issues with block 50 ... says incompatible configurations... this is for '18 ... anyone having issues too with the head lights?
I didn't have issues when I did my '18, is that the thing that pops up when you click write all or whatever? if it is that error pops up with every change you make.
