FORScan and DRL
hamster
Northern VA
Have a 2024 Raptor. Trying to get parking lights to come on with DRL. DRL only works in Auto headlight setting.
Changed BCM 726-38-01 xxxx xxxx 01 and it turned on rear tails with DRLs, but none of the other ambers / parking lights.
Changed BCM 726-38-02 00xx xxxx xx, but fogs do not come on with DRL. Manual says will not come on unless low beams are on.
I dug through all of Livnitup's spreaadsheet and tried bunch of other things I found online, but almost all of them were already the default in my truck. I triple checked my settings, took them out and re-entered them couple of times one-by-one....no joy. Did a bunch of other changes and everything works.
Any ideas?
LayinWatts69
Las Cruces, NM
I’d be willing to bet the codes vary a bit for the ‘24’s. The DRL is pretty tried and true for the 21-23’s.
Antho
The marker lamps in the grill and fenders are part of the "License Lamp" circuit now. So that has to be enabled for the markers.
There is an additional setting for the Fog lamp.
hamster
hamster
Northern VA
Yeah some did. I found one change that I needed for Mirrors-Lincoln Autofold. Spreadsheet shows:
DDM 740-03-16 xxxx xxxx 01--
PDM 741-03-16 xxxx xxxx 01--
APIM 7D0-09-01 xxxx xxAx xx--
But for 2024, it is:
DDM 740-03-16 xxxx x1xx xx--
PDM 741-03-16 xxxx x1xx xx--
hamster
hamster
Northern VA
zachery55
Rocklin, CA
Thanks. I had 4 of these, but would never have guess to change 726-87-01. I saw it, but said that can't be it. Just plugged it in and just what I wanted. Thanks!!!!!
Ima try this right now and hope it fixes my issue. I was having the exact same problem!!! Only the stock DRL set up would come on in full light none of the “extra” DRL stuff. Everything worked when auto lights came on like low light/garage. God I hope this is my fix! Trying it right now lol really wish there was a specific sheet just for type 24 raptors so there’s no confusion lol
leader32
Cypress,TX
Hey @hamster
There has been some BCM changes so it took a little while to get this one figure out but this is what i had to enable. See below.
I’m new to Forscan. What do I have to do if there is no write button? How about hyphen? I have a 2024 Raptor and currently I have not been able to have the markers and grille lights on all time.
hamster
hamster
Northern VA
No write button at all or no write button on everyline? What is your hardware/license config. Post sone detail and a pic of what you are seeing and I am sure someone can help.
95,793
59,476
egermann
