Ford Performance Tune for Gen 3s
New recaros
Colorado
There's nothing wrong with Gen 3 transmission tuning, unlike the Gen 2 in which a Cobb or other TCM tune was almost mandatory.
Thanks for your opinion. My tuned 19 using the Cobb sport TCM tune was much better than my 21 or 23. The best part is keeping the rpms up to 1200-1300 by being the correct gear and not lugging around like a damm Buick.
shigman
Cypress, TX
Uh...you must have gotten a special truck. My 2023 is just as janky and messy as my 2020. They are identical in every single way. Id pay 500 bucks just to have a transmission as sorted as the ZF 8 speeds ive had....or really any other automatic I've ever owned.
GordoJay
Colorado
Tow/haul mode fixes that for me. IMO, it's what normal mode would be in a world without the EPA.
shigman
Cypress, TX
You're correct. I keep forgetting to switch to that. It does do a pretty good job and it does seem to act like a better normal mode without being full blown sport mode.
John813
PSL/Jupiter
Not sure it makes a difference but 35 or 37 truck?
My 17 had some wonky shifts but for the most part was ok.
My 23, knock on wood, has been fine. No hard shifts or gear hunting etc. My wifes 23 expedition with the 3.73s has been great too.
Daneger
No. You leave it plugged into the OBD II port
So, if you unplug it does the tune go away? Seems like an easy install/uninstall option for the truck.
Don’t know why I’m asking because it doesn’t cover the 24 anyway. If it did I probably buy since it would be the only choice for 24’s.
YFZero
Las Vegas
You don't typically have to leave tuners plugged in unless you want to use the live monitoring functionality for extra gauges. Once you flash the tune onto the vehicles ECU you can unplug the device.
greatone99
ma
and if u need to talk about the trans tune that just means the regular tune sucks.no one really talked about the cobb trans tune ,it was all about power and boost ,
AARaptor
Katy, TX
Has anyone else installed this themselves? And once I remove the tune, would I be able to sell the tuner, or is it worthless for anyone else? Just was thinking to use this until Goose comes out with a tune for the 23
munch520
Midwest
Has anyone with an extended warranty (bought through Ford) been told the implications of this tune? I can’t get a straight answer on whether or not this warranty piggybacks off of that or stands on its own.
If the warranty with tune is on its own it would take my extended coverage from 90,000 more miles as of right now vs down to 36,000 or whatever the tune comes with. Not great.
