Ford Performance rear diff cover
thatJeepguy
GA
So on my first 2 covers (2017 and 2020), I used the gasket and bolts that came with the cover....no problems. However, I decided to try the Lubelocker gasket after taking a look at how it was made. Looks way better than the one that came with the cover. Also got the ARP Differential Cover Bolt in SS. On the 2017 I just slapped it on and the FP label looked that crap after couple of years. For the one on the 2020, I coated it and it held up better. Posted this pic somewhere and it is 4+ years old in this pic.
So while waiting for decent weather to install the one on the 2024, I mixed up some clear expoxy and sealed the label. First I leveled it all up. Came out pretty good so will see how this does after a few years. And yes I have too much time on my hands.
Fantastic idea! I just hit my cover with an aggressive wax based undercoat each year . Its ductile iron and will rust like a mf’r if the finish is penetrated.
hamster
Northern VA
That came out great! Any particular recommendation on epoxy resin to use?
Not a resin expert. Used something I got from Amazon for cheap. It said it would get rid of bubbles without any heat.....did pretty good but had to hit it quickly with a torch. But if don't have a torch, the minor bubbles would not have mattered under the truck.
hamster
Northern VA
I use Amsoil MPHD under the truck, but for some reason never thought to hit the cover....good idea.
hamster
Northern VA
I bought the Spicer version, and just jumped to the inevitable end state by simply removing the stick-on label entirely! LoL
I would have done the same if I had known that the FP one changed from rivets to just a stick on. Oh well....I will do that 5 years from now on my next Raptor.
V6Raptor
SoCal
Planning to do the swap myself over the weekend.
For those that used the ARP bolts @hamster @roger7254 , what did you torque the bolts too? I’m seeing from research ranges as low as 15 to 33 ft/lbs.
Looking over my stock cover, looks like I’ll need to reuse at least 2 OEM bolts as they have the external stud to attach the lines to. Same torque for those as the ARP bolts?
Gsteve
Report back about any hassles. I’ll be doing mine soon. Where did you find the best deal in a cover
hamster
Northern VA
Haha. Mine sitting in the garage....on my list.
