Ford Performance rear diff cover
V_K
NY
Have you had any issues since installing the FP Rear Diff cover with the ARP bolts? I plan on using these bolts as well when I swap out my cover. Any other suggestions?
V6Raptor
SoCal
Check my post, # 90.
No issues with ARP bolts but when I checked a few weeks ago, the bolts did loosen up a little.
V_K
NY
What if I use blue loctite with the ARP bolts? Would it still loosen up over time? I really want to do this, but the bolts loosening up is a bit discouraging, especially even after using the ARP bolts. I'd rather keep the stock cover on and have less headaches down the line lol.
91Eunos
Hill country, Tejas
I used Locktite red on mine….
I know there’s utility to removing the cover to really wipe down the diff housing and gears before buttoning it back up and adding new gear oil, but plan to just use an extra 1/2 quart or so every time I change it to ‘flush’ any additional debris that doesn’t drain out on its own.
I figure every third time or so I can heat up the bolts and remove them…that’s gonna get me close to another 100K miles, and realistically I’ll probably have to rebuild the diff by then anyway.
hamster
Northern VA
But Blue locktite is sufficient.
BeeEyez
california
my shop tried installing the front spicer diff cover and said that there was no room for it to clear the steering rack, is this the case with anyone else? I feel like ive seen others getting it installed? although I do believe that its not "for" raptors if im remembering correctly?
96,586
60,555
CleverGirl77
