I'm concerned about A pillar lights being stolen while parked somewhere. Any suggestions or others concerned? Seems like they would be easy for some dirtbag to make off with them
Sounds easy enough. Was thinking welding but may be too much heat for the metal provided. Soldering would workInstall the lights, aim them appropriately.
Remove the lights without changing the aim.
Fill the fallen head spots with solder.
Reinstall lights.
Use enough locktite that removing them will set off your alarm.
If you need to remove the bolts that you filled the heads on with the solder....
get out your soldering iron and melt it.
