- Joined
- Jul 18, 2017
- Posts
- 2,988
- Reaction score
- 1,397
This is kinda how I’m feelingOver the years and several Raptors, I have done lots of light options. I had dual behind the grill light bars and a-pillar mounts on my first Raptor and have scaled down with each following Raptor. Between behind the grill or a-pillar I prefer behind the grill. I prefer the cleaner/stealth look of behind the grill and while you lose some lumens because of the grill blockage, its projection is also lower to the ground and provides better close street/trail visibility than a-pillar mounts which can cut off close ground level lighting. I also like how the behind the grill lighting projects in front of the truck, while a-pillar lights project over the hood.
Definitelythe only time the a-pillar lights are good is when there is no dust/snow flying
well, pretty much any light source does that, regardless of where they’re mounted.otherwise they are hurting your nightvision..
Definitely
For sure, you fire up the pillar lights in dust, snow - hell, heavy rain and you’re creating a super bright wall of light in front of you.
I’ve staggered mine by upfitter / height by now and if it’s high dust, etc, I’m only using the low mounted lights.
maybe the wrong term... you're wrecking your long range night vision that is being lit up with near field, bright obstructions...
they are only good for clear night driving.
aha! I think I understand, and agree. if you your not in wide open terrain, the splash back from the ... I’ll call them “non spot pattern” beams is definitely going to interfere.
It took me a while to get to where my Rap is at from a lighting perspective. I think I would like one more set of spot ambers down low if I’m honest.
i have spot pattern lenses with amber covers and i barely use them.. hopefully moving them below the hoodline will help..
i think 4 white and 2 amber is what ill run, and id like to change the 7 squadrons out for an OX6 20" or maybe a laser combo bar if the money is right..
