Flashlight setup for console?
Dane
Dane
Littleton, CO
I like the setup I was planning on similar light mounted in same spot.
That little Strion is about the perfect size. It's JUST small enough to get the charger/flashlight combo in there not flush with the bottom and with just enough room to allow the removable tray to go over it on top. Just make sure you mock it up with the tray first if you still want to be able to slide it to either side without hitting the flashlight. Unplugging the charger from the 12v cord would be tough, but probably doable, though I'm not sure why I'd want/need to. I could always just remove the charger. I used that 3M stuff that has the pull tabs.
Phyguy
Denver, CO
nice idea.
I have a 4x D cell maglite jammed between the driver's seat and the console. Third truck I've had that light in the same location. Works well for numerous situations.
